How to set timing on a 92 civic dx SOHC??
Hi, I have searched but can't seem to find anything on how to set it. I am new to the Honda cars so i'm not sure how to set timing. Is the #1 cylinder the first one towards the intake? my car is stuttering and i have changed fuel filter, cleaned IACV, new cap, new spark plugs, and wires. pls. help
thanks
thanks
at start up, the car idles perfect but after 5min( when warmed up ) the idle starts the stutter and sounds like i have a misfire but when the car is rolling, it is fine. i have changed plugs, cap, rotor, fuel filter and cleaned the iacv. i am so lost.....
HELP!
HELP!
how many miles? Fuel pressure? Comp test? I see the D15B7's burn valves all the time. Get it warm and do a comp test. To rule out sticky injectors, pinch off your fuel return line and see if that helps.
ok, i checked the timing yesterday and it was way off!!! it was the marks were 1 finger to the right standing on the drivers side looking at it ( towards the fire wall )!! I adjusted back to the middle but still the same. i will check for the sticky injectors. thanks for the replies.
HiyahBeech!
Oct 12, 2007 02:53 AM
allicedout
Mar 30, 2003 08:28 AM
