How to replace tranny seal...??
Old Feb 12, 2004 | 02:15 PM
whatVTEC's Avatar
Default How to replace tranny seal...??
Does anyone know how to replace the plastic seal on the tranny?
This is the seal that goes where the shift linkage hooks to the shift shaft, it has the boot that covers it.
It's on a 97 integra. My question is does the tranny have to be broken down or can it be replaced from outside?
Old Feb 12, 2004 | 06:33 PM
RedlinedVTEC's Avatar
Default Re: How to replace tranny seal...?? (whatVTEC)
You'll have to open the case to replace that seal, sorry.
Old Feb 12, 2004 | 06:37 PM
whatVTEC's Avatar
Default Re: How to replace tranny seal...?? (RedlinedVTEC)
Damn that sucks...well I need to do the clutch anyways.
Old Feb 12, 2004 | 07:02 PM
Sliced Beard's Avatar
check my sig for a clutch
Old Feb 13, 2004 | 02:39 AM
im_poor's Avatar
Default Re: How to replace tranny seal...?? (dirtyd463)
i've seen it replace while in the car....
Old Feb 13, 2004 | 10:49 AM
whatVTEC's Avatar
Default Re: How to replace tranny seal...?? (im_poor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by im_poor &raquo;</TD></TR><TR><TD CLASS="quote">i've seen it replace while in the car....</TD></TR></TABLE>
Anyone else have any more info?
Old Feb 17, 2004 | 11:30 AM
whatVTEC's Avatar
bump
Old Feb 17, 2004 | 01:13 PM
acy76's Avatar
If you're talking about the seal around the shift rod in the trans case, I *think* you could do it while it's in the car. I installed the seal in my 92 trans (which is almost the same internally as the 97) after the trans was assembled (but before it was in the car). If you can get at it from underneath, I think it would work.
Old Feb 17, 2004 | 01:55 PM
whatVTEC's Avatar
Default Re: How to replace tranny seal...?? (acy76)
yeah, you can see it underneath the car. is there any secrets on removing it or do you just bang it out?
Old Feb 17, 2004 | 02:36 PM
acy76's Avatar
It should just pop out, and you tap a new one in.
Old Feb 17, 2004 | 03:16 PM
PhatOptimo's Avatar
The slinky looking boot pulls off then a flathead screwdriver and a hammer will pop it off. Trade licks on either side of it to work it out. Then put some oil around the new seal and pop it in with a deep socket and hammer. Replace boot and shift linkage.
Old Feb 17, 2004 | 04:13 PM
whatVTEC's Avatar
Default Re: How to replace tranny seal...?? (PhatOptimo)
Thanks
And this is all done with out taking it apart right?
Old Feb 17, 2004 | 08:07 PM
95swappedsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatOptimo &raquo;</TD></TR><TR><TD CLASS="quote">The slinky looking boot pulls off then a flathead screwdriver and a hammer will pop it off. Trade licks on either side of it to work it out. Then put some oil around the new seal and pop it in with a deep socket and hammer. Replace boot and shift linkage. </TD></TR></TABLE>
i agree never done it ....but thats the way i would go about it
Old Feb 17, 2004 | 08:22 PM
Burglar's Avatar
by the way, when mine started leaking on my GSR tranny, I stuck a D-series seal in and it fit perfectly, no leaks. kind of odd, huh? just wanted to point that out bc it may be cheaper or you may have a s-eries tranny laying around. Good luck!
Old Mar 8, 2004 | 05:47 AM
ProJectCvic's Avatar
Default Re: How to replace tranny seal...?? (95swappedsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95swappedsi &raquo;</TD></TR><TR><TD CLASS="quote">
i agree never done it ....but thats the way i would go about it </TD></TR></TABLE>
i have done it and it works!!
dopehouse
Transmission & Drivetrain
Oct 26, 2011 09:51 PM
1hotvtec
Sep 20, 2003 04:09 PM
E Swift
Jun 12, 2003 06:14 AM
X2BOARD
May 10, 2003 09:29 PM
