how to remove the snap ring from h22 tranny
Old Apr 29, 2005 | 10:02 AM
rocket_R's Avatar
Default how to remove the snap ring from h22 tranny
i'm installing a lsd. i know i'm soppuse to take off the snap ring in order to take the case apart but how do i do that?? am i just soppuse to spread it apart? i did that and it allow me to loose half of the tranny but not the other. any sugguestion????
Old May 4, 2005 | 09:01 AM
legendboy's Avatar
Default Re: how to remove the snap ring from h22 tranny (rocket_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket_R &raquo;</TD></TR><TR><TD CLASS="quote">i'm installing a lsd. i know i'm soppuse to take off the snap ring in order to take the case apart but how do i do that?? am i just soppuse to spread it apart? i did that and it allow me to loose half of the tranny but not the other. any sugguestion????</TD></TR></TABLE>
you have to get two screw drivers in either side and get the case at least starting to seperate. Then spread the clip and pry the case evenly apart. Just did it last night
Old May 4, 2005 | 11:16 PM
rocket_R's Avatar
Default Re: how to remove the snap ring from h22 tranny (legendboy)
so sure i spread the ring while i'm prying it?? thanx for the help.
Old May 5, 2005 | 05:47 AM
tgreaves's Avatar
I always use a long pair of needle nose pliers to open the ring up..
Old May 5, 2005 | 07:07 AM
machine4321's Avatar
once the ring is spread the counter shaft should fall out enough so that it doesnt hold it in there .....if your doing it withth etranny on its side then it wont work to easy ...tip it so the snap ring is on the top ..(put somthign under the tranny so the input shaft isnt touching the floor .....doth forget the 2 14mm bolts around the shifter area...all the resat are 12mm around the out side
then youll have to pry up on the case in a few spots to break the seal ..then it shoudl lift off ..
any thignk else let me know
Old Sep 8, 2005 | 07:03 PM
sparxx's Avatar
Default Re: (machine4321)
now how would you get it back on?is there a trick to it, or just lots of patience?
thanks
Old Sep 8, 2005 | 08:26 PM
h22 civic's Avatar
Default Re: (sparxx)
pep boys snap ring pliers
Old Sep 12, 2005 | 10:32 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (h22 civic)
sears..........
Old Sep 13, 2005 | 12:59 PM
getting it back on is another story lol . i would drop the case on and when it was as close dow i would tilt it on its side (carfully ) and use the snap ring pliers (there really needer to get it back on ) and kind tossi it side to side in hope the bareing seat in and the shaft locks in
it takes time and many many trys
Old Sep 13, 2005 | 01:37 PM
Mista Bone's Avatar
D Tranny Guru
you make it sound hard............
while lowering the case, spread the sanp ring over the bearing, install case bolts, flip tranny over and listen for the click..........
or the He-Man method, instead of turning the tranny over, lift and drop quickly.
Turning the tranny on it's side is asking for a leak while the sealant is setting up.
Old Sep 13, 2005 | 06:45 PM
true but on the hseries ive worked on the countershaft doesnt reall sit up as far as i ithkn it should have , the few ivwe been into had play that didnt allow me to do that
Old Sep 20, 2005 | 09:34 AM
nitroeg's Avatar
changed some synchros while your in there stock synchros suck on h22 tranny specialy 2nd gear
dohc_profile
Jan 8, 2007 05:26 PM
j spec
Oct 6, 2005 05:25 PM
Monkey Fing a Coconut
Dec 12, 2003 07:32 AM
Magnaflow
Oct 22, 2003 02:58 PM
Magnaflow
Aug 31, 2003 06:19 PM
