How to remove oil stain from concrete?
Old 11-26-2006, 05:56 PM
jrockets's Avatar
Default How to remove oil stain from concrete?
Yea I am wondering if any of you have any secrets or products that will remove oil stains from concrete?
Old 11-26-2006, 05:57 PM
jdmztrane's Avatar
Default Re: How to remove oil stain from concrete? (jrockets)
Try some of the generic degreasers in their concentrated from along with a pressure washer. Should come right out, unless its been on the concrete for a long time.
Old 11-26-2006, 05:58 PM
Reza^'s Avatar
go to homedepot and ask what you can use..
Old 11-26-2006, 06:03 PM
jrockets's Avatar
Default Re: How to remove oil stain from concrete? (.:Reza:.)
does anyone know if pour-n-restore.com work...
Inline6 Silvia's Avatar
brake cleaner
Old 11-26-2006, 06:05 PM
Bloody Beaver
.Beaver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:Reza:. &raquo;</TD></TR><TR><TD CLASS="quote">go to homedepot and ask what you can use..
Old 11-26-2006, 06:10 PM
bart2546's Avatar
Default Re: How to remove oil stain from concrete? (Teal-EJ1)
If it's fresh, some stuff called "purple power" letting it soak for a few, then a high powered pressure washer FTW. Or put down some generic kitty litter and then using the above. Other than that, brake cleaner works well.
Old 11-26-2006, 06:17 PM
kyle h.'s Avatar
again too much effort...
brake cleaner and rags always worked for me.
Old 11-26-2006, 06:24 PM
RIP 1032
life sux die's Avatar
Default Re: How to remove oil stain from concrete? (Yellowone)
tide with bleach worked for me!
Old 11-26-2006, 06:39 PM
jdmazm's Avatar
Default Re: How to remove oil stain from concrete? (EK Josh)
degrease then dump on some kitty litter, then degrease one more time.
Old 11-26-2006, 09:14 PM
Reza^'s Avatar
this thread is done.
go to home depot.
Old 11-26-2006, 09:41 PM
plan B.'s Avatar
try starting fluid. you can get it at kragen or something. i used it the other week and it worked great. i guess it has like ether or something in it and its only like 2 bucks a can.
Old 11-26-2006, 09:57 PM
ATS*VEEE's Avatar
Default Re: (plan B.)
if its fresh OIL stain...try COKE...yes COKE...coca-cola..hahah...it works somewhat...and wash if off with water
Old 11-26-2006, 10:11 PM
BoostedCivicChic's Avatar
castrol degreaser...in concetrate 1 gallon purple bottle in the automotive section at most places like wal-mart mix with water (real ****)
Old 11-26-2006, 10:50 PM
prettycivic's Avatar
You can't.
Old 11-26-2006, 10:52 PM
plan B.'s Avatar
Default Re: How to remove oil stain from concrete? (prettycivic)
yes, you can. have you even ever tried starting fluid?
Old 11-26-2006, 10:57 PM
DOMKID's Avatar
Default Re: How to remove oil stain from concrete? (plan B.)
pressure washer and some chemicals should fix the problem, but its very hard to take it completely off.
Old 11-27-2006, 10:14 AM
Azn Kenny's Avatar
Pave new concrete over it...
Old 11-27-2006, 11:44 AM
gsrious's Avatar
go and buy some balck paint and paint the whole drive way/garage floor black. then you wont have to worry about the stain anymore.
^j/k
you should always wipe off any excess oil first. then do what others have said. repeat those muiltiple time for a lasting effect.
Old 11-27-2006, 10:59 PM
Shack,96's Avatar
tide with bleach does the trick for me also,use broom then pressure washer.
alexsracing
01-23-2008 06:07 PM
JDMCRX
Welding / Fabrication
19
01-03-2008 09:28 AM
robble36
10-08-2007 07:54 PM
Rhetoric
08-06-2003 12:59 AM
Soon_2b_evil
07-18-2003 05:36 PM
Quick Reply: How to remove oil stain from concrete?
