How to remove oil stain from concrete?
Yea I am wondering if any of you have any secrets or products that will remove oil stains from concrete? https://honda-tech.com/forums/images/smilies/emwink.gif
Re: How to remove oil stain from concrete? (jrockets)
Try some of the generic degreasers in their concentrated from along with a pressure washer. Should come right out, unless its been on the concrete for a long time.
Re: How to remove oil stain from concrete? (.:Reza:.)
does anyone know if pour-n-restore.com work...
brake cleaner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:Reza:. »</TD></TR><TR><TD CLASS="quote">go to homedepot and ask what you can use..
https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: How to remove oil stain from concrete? (Teal-EJ1)
If it's fresh, some stuff called "purple power" letting it soak for a few, then a high powered pressure washer FTW. Or put down some generic kitty litter and then using the above. Other than that, brake cleaner works well.
again too much effort... https://honda-tech.com/forums/images/smilies/emthup.gif
brake cleaner and rags always worked for me. |
Re: How to remove oil stain from concrete? (Yellowone)
tide with bleach worked for me!
Re: How to remove oil stain from concrete? (EK Josh)
degrease then dump on some kitty litter, then degrease one more time.
this thread is done.
go to home depot. |
try starting fluid. you can get it at kragen or something. i used it the other week and it worked great. i guess it has like ether or something in it and its only like 2 bucks a can.
Re: (plan B.)
if its fresh OIL stain...try COKE...yes COKE...coca-cola..hahah...it works somewhat...and wash if off with water
castrol degreaser...in concetrate 1 gallon purple bottle in the automotive section at most places like wal-mart mix with water (real shit)
You can't.
Re: How to remove oil stain from concrete? (prettycivic)
yes, you can. have you even ever tried starting fluid?
Re: How to remove oil stain from concrete? (plan B.)
pressure washer and some chemicals should fix the problem, but its very hard to take it completely off.
Pave new concrete over it...
go and buy some balck paint and paint the whole drive way/garage floor black. then you wont have to worry about the stain anymore.
^j/k you should always wipe off any excess oil first. then do what others have said. repeat those muiltiple time for a lasting effect. |
tide with bleach does the trick for me also,use broom then pressure washer.
