How much can a b16 be bored out?
Old Sep 21, 2001 | 12:04 PM
Bert's Avatar
Default How much can a b16 be bored out?
Hello,
I was wondering what the maximum a b16 block can be bored out to if you are planning on getting some aftermarket sleeves anyways. It seems like you could save some money if it could be bored to something approaching 1.8l while maintaining the b16 rod ratio.
Thanks.
Old Sep 21, 2001 | 12:10 PM
Crazy DA's Avatar
New User
Default Re: How much can a b16 be bored out? (Bert)
service manual that i have says the max that can be bored out for the B17A1 is .25mm over. i assume it is the same for the B16? with aftermarket sleeves, i'm not sure.
[Modified by Crazy DA, 9:11 PM 9/21/2001]
Old Sep 21, 2001 | 12:20 PM
Sonic's Avatar
Default Re: How much can a b16 be bored out? (Crazy DA)
Bert,
If you want a 1.8 with the B16 R/S ratio, take a B20 block, put in a B17 crank, Endyn rods/pistons, B18C block girdle and oil squirters and you'll be all set. The final cost is probably less than resleeving, not to mention having to get custom pistoons made for the application...
Old Sep 22, 2001 | 12:45 AM
Shoe's Avatar
New User
Default Re: How much can a b16 be bored out? (Sonic)
Just buy a GSR block..
Old Sep 22, 2001 | 06:07 AM
rainforest's Avatar
Default Re: How much can a b16 be bored out? (Shoe)
my 2 cents would be the most to bore it with aftermarket sleeves is to a 85mm 1mm over the stock b20b so you can retain a 1.74 r/s ratio and still be a 1.9 liter if my estamating is correct. Don't feel like doing the math.
b16a4
Feb 5, 2007 12:43 AM
MKcrxB16
25
Jul 20, 2006 11:36 AM
dominicanito49
Jul 18, 2006 06:41 PM
agreziv89ef-8
Apr 24, 2004 04:39 PM
SpdFrk
Aug 29, 2003 07:42 AM
