How to make the Vtec work?
Old Jun 18, 2002 | 02:00 PM
tiiiteSedan's Avatar
Default How to make the Vtec work?
I have a 1997 Civic Lx and i just installed a 95 Si (canadian) because i blew up the stock engine and while my ls/vtec project is in work i need a ride to go work...... and i would like to know how to connect the VTEC.
I've kept my OBD2 wiring harness and my stock ECU and i'm using them for my 95 Si engine.
What do i need to make the VTEC work....should i get a 92-95 Si ECU (but i think i will need to modify my harnness) or simply install a switch to control my Vtec manually ( but after one day i'll get pissed)..???????
Please help
Thanx
Old Jun 18, 2002 | 02:30 PM
Spade's Avatar
Default Re: How to make the Vtec work? (tiiiteSedan)
need to convert wiring harness from OBDII to OBDI.
Old Jun 18, 2002 | 03:23 PM
one of my friend told me to plug a wire on the wire of the vtec selonoid and feed it with 12 volt with a fuse between the 12 volt and tghe vtec wire with a witch at the end.
Is this possoible....i don't mind to activate the vtec manually....just tell me if it's possible or not
Old Jun 19, 2002 | 12:22 AM
kinesistech's Avatar
Yes, it'll work, but thats super ghetto. I just bought a vafc. Any vtec controller will work. Plus you dont really want to flip a switch every time you want vtec. Thats absolutely rediculous.
You will have a check engine light though. You see, your obd2 brain wants to see the signal from the crank shaft fluctuation sensor. Its the one bolted to the stock oil pump with wires running up towards the intake manifold. To make the obd1 engine work, you will need to install an oil pump for a 96-up engine. It'll fit just fine but it will also have the provision for mounting your sensor from the exploded motor. Also, you'll need to use the obd2 injectors because the plugs are different from obd2 to obd1.
Old Jun 19, 2002 | 05:17 AM
Default Re: How to make the Vtec work? (kinesistech)
Yeah i know it's ridiculous......but it's only temporary.....and as i say i have a Ls/vtec in construction.
So you say it will work with a switch....cool.......i'll try to arrange that.
Anyone know if there is a website providing diagram on the installation?
Old Jun 19, 2002 | 05:22 AM
98DC2's Avatar
All you need is a conversion harness (OBD11-OBD1). i actually have a 98 LX, was going to do swap, but decided to put up for sale, & start on a new car. good luck!
Old Jun 19, 2002 | 05:51 AM
Default Re: How to make the Vtec work? (98lagen)
yeah lot of people told me that (harness conversion from OBD2 to OBD1)...but i don't want to waste money on that...and i don'T know how to convert it.
I have the stock ECU inside my car the one coming with my D16Y7...all i know my friend could give me his P28 ecu.
What do i need to convert the harness.....again and again is there a website showing that?
Old Jun 19, 2002 | 12:00 PM
salbaje's Avatar
use the 95 si motor with harness and 97 ex ecu. if you need to run a wire from vtec solenoid to ecu. Also vtec oil press.
Old Sep 27, 2016 | 04:39 PM
f22b2's Avatar
Hey guys i have a 90 integra with jdm b16a obd0
When i buy the car the knock sensor was broke so i replace and 1 week ago i replace the ecu pr3 old and new are the same ecu but i still getting the cell.23 knock sensor
Last owner just swapped but he never run the engine
After 4000 rpms my check engine light get on and vtec not work
Im thinking too replace the knock sensor
The engine was obd1 and he make obd0
And all ecu pinout are good
Wire and plug are good
Any idea.... don't want spend money on changes wire and other ecu
zackmith11
Honda Civic (2001 - 2005)
Aug 13, 2014 07:36 AM
swizz977
10
May 25, 2011 08:15 PM
jetoutant
11
Jan 2, 2008 07:50 PM
Ckramer
Jul 3, 2007 12:18 PM
hondaless
Sep 17, 2002 06:33 PM
