How long are ctr rods?
Yes, it is a B18C/P72 block with a 1.6L crank and longer rods. It is a 1.6L crank, but it's not exactly 1.6L crank out of a B16A engine; it's a special 'R' prepped 1.6L crank, which is made along the same procedure as the ITR crank, and is specifically designed for the P72 block+crank journals. This B16B crank has a less-width journal area, same as you'd find on a GSR or ITR crank; and its counterweight balanced. Regular B16 cranks have wider crank journal area's and are not counterweight balanced.
I don't have the exact length specs on them, but I do know for a fact that they're the longest b-series rod. I've compared them to B18C rods and they're a few cm's longer.
[Modified by Katman, 9:01 AM 11/18/2002]
That sounds about right... I thought the R/S of a CTR was like 1.84 and with a 144mm rod it's about 1.87.... Oh well when i find out for sure i'll post back up... Peace
Only the rod journals are wider. the mains are the same.
ahh yeah, ok..thanks.
I knew there was some differences between B18C/CTR and B16A crank journal widths somewhere.....thanks for the clarification.
Bumping the thread.
b16b rods use 142.42mm rods with
77.4mm crank.
142.42 / 77.4 = 1.84
Anyways, i have this query - if we use an 87.2mm crank from a b18c with b16b rods we would have a
1.63 stroke ratio - more stress upon the cylinder walls, BUT...
What im trying to achieve is a better stroke ratio for a b20 capacity - which from factory has a
1.53 stroke ratio (137.01mm rods and 89mm crank)
I am wanting to utilize...
B16B Civic Type R rods 142.42mm long
B18C Type R Crank 87.2mm Stroke
and a sleeved 84 or 85mm B16b or b18c series VTEC block.
My question is, with that setup^ are [aftermarket b20 84/85mm] pistons going to clear the valves? Probably not. Custom pistons with pins located higher in the piston I'm guessing?
77.4mm crank.
FakeJDMEF8
Sep 14, 2004 09:25 PM
eddiecut
Apr 1, 2003 03:18 PM
