How to Install Headers!!!!
Old Feb 2, 2003 | 06:24 PM
Rukusmasta2's Avatar
Default How to Install Headers!!!!
i have a 94 ex accord and im goin to buy headers this week...i want to put them in myself...can someone give me a step by step guide and everything i need all tools and accessories so i can get it ahead a time and do this project this week....
Old Feb 2, 2003 | 06:37 PM
altoid's Avatar
Default Re: How to Install Headers!!!! (Rukusmasta2)
you've got a v6? just unbolt it from everything its attached to. they're 10mm bolts i believe, if not that they're 12 mm for sure
Old Feb 2, 2003 | 06:40 PM
Default Re: How to Install Headers!!!! (altoid)
na i got the sohc vtec 4 cyl
Old Feb 2, 2003 | 06:41 PM
tek_civic's Avatar
also get a haynes or chiltons repair manual, believe me, it will help you at some point.
Old Feb 2, 2003 | 06:42 PM
Kamin's Avatar
headeR
no s dude, you only have 1.
header.
remove the 10? 12mm bolts (dont exactally know how many) on the front of the engine holding the stock header on, remove the 2 spring bolts holding the car to the header, remove the 2 bolts holding the header to the header bracket, UNCLIP the o2 sensor
once the header is free remove the o2 sensor (be VERY careful)
install the o2 sensor into the new header, then install the new header. make sure the exhause manifold gasket is between the header and the head, its a flimsy piece of aluminum but make sure its still there. and when bolting the cat to the header, the spring loaded bolts, make sure the lip on the bolts go THROUGH the car and sits between the header and cat (youll understand when you see it)
Old Feb 2, 2003 | 08:49 PM
Nameless RB26's Avatar
Default Re: How to Install Headers!!!! (efzero)
forgot to add mad HEADER"S" yO! to my post HEADERS HEADERS HEADERS HEADERS I am gonna get HEADERS HEADERS HEADERS HEADERS HEADERS HEADERS HEADERS HEADERS HEADERS HEADERS HEADERE
haha.
Spray some lube on the cat bolts... let them soak. Might even want to hit them with a hammer first to loosen them up.
Old Feb 2, 2003 | 08:53 PM
Kamin's Avatar
Default Re: How to Install Headers!!!! (Nameless)
i used 2 wrenches and pulled in opposite directions reeeeealy hard.
when that didnt work i got out my BFH and b.eat on one of the wrenches.
worked like a charm.
[Modified by Kamin, 9:54 PM 2/2/2003]
Old Feb 3, 2003 | 07:55 AM
X0's Avatar
X0
One more thing...
Don't touch the business end of the o[sup]2[/sup] sensor. The oil and crud that WILL be on your hands can ruin the sensor.
Dahl Sol
Nov 30, 2009 01:51 PM
Deemeetree
48
Nov 7, 2008 06:07 AM
Cornering Artist
Honda S2000
29
Mar 4, 2007 05:42 PM
GSR2001
Feb 22, 2002 09:09 PM
Kellindal
Sep 22, 2001 12:25 AM
