Prying/removing tranny from engine
Old Feb 14, 2004 | 05:45 PM
integraGSR213's Avatar
New User
Default Prying/removing tranny from engine
All bolts have been removed and tranny is free, but I can't get it off the engine using pry bars. Don't want to damage engine, what should I use and where is a good spot to try and pry things open in order to seperate tranny for removal. Thanks
Old Feb 14, 2004 | 08:46 PM
everidge4's Avatar
Default Re: Prying/removing tranny from engine (integraGSR213)
did you take off the flywheel dust cover? Also there is a bolt under the starter. Finally if that fails check all bolt holes agian and make sure you did not skip one. Once they are all out it should not be hard to get it off unless the car is way unlevel
oh and you have to take the mount bracket on th back of the motor off
Old Feb 14, 2004 | 09:43 PM
Toda Built's Avatar
Default Re: Prying/removing tranny from engine (crackalackin)
Did you remove the starter? And there is a bracket on the back of the tranny that connects to the block. If that fails use a rubber mallet and just bang on the corners of the tranny to jar it loose
Old Feb 14, 2004 | 10:00 PM
xSCTYGx's Avatar
Default Re: Prying/removing tranny from engine (Toda Built)
just took mine out tonight...mine was a lil more involved just because i had to take the whole axle assembly out due to my gay axle nut taht wouldnt come off, but yea just make sure ya got every bolt out..then just slide the tranny out..
Old Feb 16, 2004 | 11:19 AM
New User
Default Re: Prying/removing tranny from engine (2Gen91Teg)
The last bolt was the starter bolt. I didn't realize I missed that one. haha
it came off easy after that.
thanks
petty$rep
Oct 6, 2006 01:18 PM
rice a roni
11
Apr 26, 2006 05:10 PM
tallblondkid
Aug 11, 2004 01:32 AM
triggerX
Apr 24, 2004 12:03 AM
civickiller
10
Aug 12, 2003 12:44 PM
