how does a Vehicle Speed Sensor (VSS) Work?
Old Feb 14, 2006 | 07:59 AM
variablevalve's Avatar
Default how does a Vehicle Speed Sensor (VSS) Work?
I'm curious to how a vehicle speed sensor actually works. I found out that there is some kind of VSS Gear but could someone expand on that for me? Thanks.
Old Feb 14, 2006 | 08:11 AM
tgreaves's Avatar
Default Re: how does a Vehicle Speed Sensor (VSS) Work? (variablevalve)
The gear is on the diff and it drives the gear on the vss unit.. It pulses +12volts per revolution of the vss sensor.. I think its like 4000 pulses per mile on average..
Old Feb 14, 2006 | 08:24 AM
Default Re: how does a Vehicle Speed Sensor (tgreaves)
Thanks
Old Feb 14, 2006 | 09:56 AM
rorik's Avatar
the same basic way a crank angle sensor, etc works..
Old Feb 14, 2006 | 10:39 AM
EK-Chris's Avatar
Default Re: (rorik)
it spins.
Old Sep 7, 2019 | 10:48 AM
azchris's Avatar
The VSS pulls the signal to ground as it rotates (and there is a resistor which pulls the signal back high inside the car electronics on the sensor line)
I have a 95 Accord and I tested the Speedo/Odo on the bench. (it requires only 3 connections, Ground, IGN @+12v, and the VSS/sense signal)
I connected a function generator providing a square wave to pull the Speedo/Odo sense signal to ground.
I measured the pulse at 15ms period (66.67Hz) when the speedo read 60MPH. (and at 10ms period, the speedo read 90MPH).
This corresponds to 66.67/sec* 60sec/min = 4000 pulses per minute.
That matches what was stated in this post "about 4000 pulses per mile", because 60MPH is one mile per minute.
The VSS pulls the signal to ground as it rotates.
In general, the Speedo MPH = approximately 900/(period of signal in milliseconds).
The Honda factory manual states that the speedo indicates 60mph@1026RPM of the VSS.
That would be 1026rev/min * (1min/60sec) = 17.1Hz or 58.45ms.
However, that does NOT seem to match what I measured.
(scaling my measurement, 58.45ms period would give about 15MPH).
However, assuming that the VSS produces 4 pulses per revolution, that explains the factor-of-4 difference.
So,
1026 rev/min * (1min/60sec) * (4 pulses/revolution) = 68.4 pulses/sec @ 60mph
1 / (68.4 pulse/sec) = 0.01462sec = 14.62ms period at 60MPH.
Since the period and MPH are inversely-related,
14.62 ms * 60MPH = 877.193 ms*MPH = Constant.
so, using Honda's 'exact' value:
mph = 877.193 ms * MPH / (signal period in mS)
The matches pretty closely to the measurements I took.
Period (ms) = 877.193 (ms*mph) / 60MPH = 14.62 ms (vs. measured value of 15ms)
Period (ms) = 877.193 (ms*mph) / 90MPH = 9.75 ms (vs. measured value of 9.92ms)
(My speedo reads a bit fast anyway!)
Old Sep 7, 2019 | 12:27 PM
It Wasn't Me's Avatar
So,
This thread is from 2006.
Old Sep 7, 2019 | 01:00 PM
azchris's Avatar
yes but I'm adding some info I feel might be useful to others. For example, if someone wants to test their speedometer off the car like I did,
to test accuracy or if it's not working.
These cars seem to have bad solder joints in the control board at the back of the speedometer
e.g. https://honda-tech.com/forums/honda-...epair-2087284/
and there are various videos and forums discussing resoldering the board and 'pin 10' on the IC#1.
So I wanted to be able to test my speedo without having to jack the car up and run it to actually test it.
Old Sep 10, 2019 | 12:50 PM
DaX's Avatar
DaX
Loved
Community Favorite
Appreciate the additional tech info, @azchris
Old Aug 17, 2020 | 10:41 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
x2 - really appreciate the info @azchris
blaze.1
Sep 10, 2009 06:24 AM
thannon2
22
Jan 20, 2009 08:04 PM
thannon2
Jan 16, 2009 01:59 PM
b frisco
Mar 5, 2008 10:11 PM
nenacivic23
Aug 30, 2004 03:18 PM
