How does this thing come off?
Old 08-16-2002, 07:09 AM
senpai's Avatar
Default How does this thing come off?
This is the lower ball joint. I need the WHOLE thing to come out of the knuckle so I can replace it. The bottom threads are BAD!
Here is a picture:
It is number [3] in that picture.
THANKS!
Old 08-16-2002, 07:11 AM
BROOD's Avatar
Default Re: How does this thing come off? (maztur)
The lower ball joint has to be pressed out. You will need a machine press to do it. Any shop that can replace wheel bearings can usually press out the old ball joint and press in the new one.
[Modified by SLPR, 8:14 AM 8/16/2002]
Old 08-16-2002, 07:12 AM
Spade's Avatar
Just get a.....damn I hate forgetting words.....re-thread the bolt dammit.
ScrapinSi's Avatar
Press it..
Old 08-16-2002, 07:18 AM
Ehron's Avatar
Default Re: How does this thing come off? (Spade)
tap and die? <-- damn word?
Old 08-16-2002, 07:19 AM
Spade's Avatar
Default Re: How does this thing come off? (Ehron)
Old 08-16-2002, 07:37 AM
93CivicSI's Avatar
remove the c clip - (on some models) and then rent a ball joint kit from Autozone or Trak Auto (in NVA area) - took me about 20 minutes each side.
Old 08-16-2002, 10:18 AM
tooqwik1's Avatar
Default Re: How does this thing come off? (93CivicSI)
if u dont have a ball joint puller u take a hammer and on the side of the arm u will see a lil bump smack it very hard a few times then try to bull the knuckle out or if u have a friend there have him pull on the knuckle while hammering
Old 08-16-2002, 11:30 PM
D Tranny Guru
Mista Bone's Avatar
remove c clip, beat it out. Install new BJ with C frame press from Autozone or Harbor Freight
Old 08-17-2002, 02:06 AM
civicgsr94's Avatar
3 pronged bearing puller worked for me. if you don't feel like buying one most auto stores rent them out.
PatrickGSR94
Suspension & Brakes
18
05-12-2010 09:55 AM
Dwight Schrute
04-20-2007 03:42 PM
GruvyTune
08-10-2004 11:30 PM
Flamenco-T
08-21-2002 11:49 PM
97hb
03-09-2002 11:31 PM
Quick Reply: How does this thing come off?
