How do you "Jump" a starter??
Old Jul 27, 2009 | 08:53 AM
HT Chaplain's Avatar
Loved
Default How do you "Jump" a starter??
93 EX wont turnover checked grounds and battery everything is good. How do you jump the starter? Do you just get wire and touch the two terminals on the starter together? I did that and still nothing?? bad starter??
Old Jul 27, 2009 | 01:26 PM
srmofo's Avatar
Default Re: How do you "Jump" a starter??
use jumper cables or similar guage wire. connect the B+ from battery to the small wire on the starter solenoid
what problems are you having?
Old Jul 27, 2009 | 07:41 PM
gt35rSI's Avatar
If you use the screwdriver trick you have to make sure both connections no **** make good contact. Or get a wire and connect one end to the pos side of the battery and the other side connect to the ign wire on the starter. If nothing your starter is done and if it works your ign is not sending the signal to crank
Old Jul 28, 2009 | 05:33 PM
Loved
thanks guys ended up being a bad starter
hondachris1994
12
Nov 9, 2017 05:15 PM
stevewa
Nov 24, 2011 10:15 AM
twentyhurtz
Dec 14, 2009 12:28 PM
bayoufrogg
Oct 24, 2006 08:18 PM
