how do you flush a radiator?
Old Nov 9, 2002 | 12:26 PM
White S2k's Avatar
Default how do you flush a radiator?
what do you do to flush a radiator?
Old Nov 9, 2002 | 01:31 PM
b00stn's Avatar
Default Re: how do you flush a radiator? (whiterice42019)
I think you drain the fluid and run the car with a hose running water through the system. Then refill it with new fluid. Not sure though.
Old Nov 9, 2002 | 02:37 PM
White S2k's Avatar
Default Re: how do you flush a radiator? (b00stn)
anyone else?
Old Nov 9, 2002 | 03:09 PM
chevyalltheway's Avatar
the best thing to do when flushing radiator is to take it out and attach hose to the plug that fluid usually comes out of. So the radiator is flowing in reverse from when in car. reason for pulling radiator is cause it gets messy.
Old Nov 9, 2002 | 03:39 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: how do you flush a radiator? (chevyalltheway)
the real way is to remove the coolant drain plugs and your radiator cap and stick a hose in the radiator and start up your car and let water run through and pour out of the block. You could also just detatch the top radiator hose and angle it away from your engine and run the hose to the top of radiator- these 2 will flush your ENTIRE system, the other just flush the radiator
Halo
Mar 18, 2012 10:15 PM
plusONE jboy
Dec 25, 2004 11:23 AM
B18Redline
Dec 2, 2004 09:35 AM
lDanny
Feb 13, 2004 02:20 AM
geminis2k
Sep 16, 2002 06:29 PM
