How do i time My D16??..
Im so close to getting it running but after reinstalling both Timing belt and water pump, i think i might have turned the crank a bit..Now when i crank it is not have a familiar crank..it sounds different...How do i go about timing it right??
you need a honda service manual to set your timing correctly.
or at the very least a haynes/chilton manual that u can get at local autoparts stores(those do not have nearly as much info as the real deal helms manual though).
they can tell u how to set ur cam/crank timing.
you'll also need a timing light for ignition timing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_CRX_Si »</TD></TR><TR><TD CLASS="quote">Im so close to getting it running but after reinstalling both Timing belt and water pump, i think i might have turned the crank a bit..Now when i crank it is not have a familiar crank..it sounds different...How do i go about timing it right??</TD></TR></TABLE>
If the crank moved, why didn't you just move it back to TDC? It's not like there's some kind of secret here.
1. Set #1 piston to TDC
2. Make sure the cam gear timing marks are parallel to the head
3. Install belt.
3. Install belt.
I dont have any marks how the Chiltons says(white Mark) to set the crank to TDC...I know the cam timing is correct upbut how else can i tell if im settin it to TDC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_CRX_Si »</TD></TR><TR><TD CLASS="quote">I dont have any marks how the Chiltons says(white Mark) to set the crank to TDC...I know the cam timing is correct upbut how else can i tell if im settin it to TDC</TD></TR></TABLE>
There have to be marks on the crank pulley. Even aftermarket pullies have the marks.
There should be three close together, then one spaced farther apart. Like this:
The mark by itself (on the right) is the TDC mark.
Ok i got the car running starts great, but the response is very bad...Does not revv up like it use to...
...Took it for a test ride and its alot slower when i get on it..Any suggestions.
