13 second prelude
Old Jan 11, 2003 | 10:02 PM
NZ Vtec Weapon's Avatar
Default 13 second prelude
im currently doing a 14.508sec 1/4,ive got:
exhast
cold air take+filter
enlarged throttle body
lightened pullie
lightened flywheel
9.3mm leads
race seat(5kg)
,what else do you prelude dudes in the 13's suggest??
Old Jan 11, 2003 | 10:03 PM
weakGOODJunKieS.com's Avatar
Default Re: 13 second prelude (NZ Vtec Weapon)
turbo
fcardoso's Avatar
Default Re: 13 second prelude (cnguyen32)
NOS or Turbo!!
Old Jan 11, 2003 | 10:07 PM
Default Re: 13 second prelude (fcardoso)
staying n/a ya cheeky sobs
Old Jan 11, 2003 | 10:14 PM
stripp interior
edit- slicks
[Modified by cnguyen32, 7:15 AM 1/12/2003]
Old Jan 11, 2003 | 10:25 PM
fcardoso's Avatar
Camshaft, springs, Port and Polish, performance ECU, VAFC, Ignition box!!
These are just some of the things you can do!!
Old Jan 13, 2003 | 07:43 AM
TurboLude97's Avatar
i have t3/t4, UR pulleys, flywheel, clutch, ntercooelr and im running 13.0 @ 107 (and should be able to get into the mid/high 12's next year with a few more mods) btw this is @ 10 psi, pump gas, full interior, skunk 2 springs and slicks.
Old Jan 13, 2003 | 07:51 AM
VRD^don's Avatar
high comp pistons...stay n/a
Old Jan 13, 2003 | 08:18 AM
SergEK's Avatar
Default Re: 13 second prelude (sohc_vtec)
Skunk2 stage 1 cams
Type S valvetrain
Raise the comp up to at least 11.5:1 if not higher
JUN flywheel
Drag radials - Not slicks
Possibly raise your FD
Adj shocks...tuning your suspension will be a key to droping your 60's
VAFC- a must for light tuning - Hondata or AEM standalone would be better
Those are just a few basic things that will take you some time to buy. The main part of 13's will be you....get your launch down to consistent 1.9's and you should see some nice 13 sec timeslips very soon.
Old Jan 13, 2003 | 09:08 AM
HaleLude's Avatar
stripp interior
In my opinion you should never strip a Prelude interior. If you really want light weight swap the H motor into and older civic. Do what you want but I think it's a waste. Just get a 50-75 shot to make up for the creature comforts.
Old Jan 13, 2003 | 09:34 AM
2point6's Avatar
Default Re: 13 second prelude (HaleLude)
check out this thread:
https://honda-tech.com/zerothread?id=383941
Old Jan 13, 2003 | 02:06 PM
Default Re: 13 second prelude (2point6)
Yea want to stay NA as im competitive in my class,+ ive got shocks. My launches and 60' are usually a 2.3 alotta weight to start to move!!
Old Jan 16, 2003 | 12:42 PM
2point6's Avatar
No kidding on the weight issue, but maybe I can help out a little. Check out my site if you like... http://www.collectiveracing.net There is a couple of 13 sec NA preludes who post there.
Old Jan 22, 2003 | 05:41 PM
Lith's Avatar
How much power would you guys expect to require for a full interior Prelude to get into the 13s in NA form? (some people seem to count NOS as NA - I am talking real NA, so a 75hp NOS hit is not an option).
I have been stuck on 2.5s 60ft times on a crappy track, with cheap tires etc - and have been running 14.7s with mph in the high 90s...
I have sorted out traction and will be running in 2 weeks time on a prepped track, hoping for 2.2-2.3s 60ft times - would mid-low 14s be a reasonable target?
[Modified by Lith, 2:43 AM 1/23/2003]
Old Jan 22, 2003 | 07:06 PM
Default Re: 13 second prelude (Lith)
getting tracions one thing,having the power to do the times and,believe it or not,the driver has abit to do with it.ive still got traction probs,but not as bad,ive done 20odd 14.5s,and tried heapsa lil things,but ive got what things i need to do next sussed to edge closer to a high 13.im still full interior by the way
Old Jan 22, 2003 | 08:28 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
There's a start. You should be able to pull a 2.1 on good street tires and at least a 2.0 on drag radials if not better. Heck I've pulled 2.0's on SO-3's. A mild set of cams and some good tuning should be enough if you can get a lower 60'.
Old Jan 23, 2003 | 12:18 PM
Lith's Avatar
Yeah, been over that - I run mine as I drive on the street... full interior, exhaust, street tires etc etc, and I am going to run that at my next meet as well. I'm having a little break from power mods, doing ~185fwhp as per my last tuning session which is IMHO sufficient to do much quicker than 14.7 - but with no decent traction its not being made good use of.
My driving is fine, theres only so much you can do with endurance compound 195mm wide tires ;p Same as what you typical grandma would use on her Toyota Corolla. From what I've seen over the last few months traction has more to do with getting quicker times (to an extent of course) than adding power, as power gains in NA form tend to be minimal.
You can shave more time by dropping from 2.5s 60ft to 2.4 (etc etc) than you could by gaining 10fwhp from what I have seen lately.
h22_crx
Aug 6, 2006 12:58 PM
Quik Chris
Feb 5, 2003 01:02 PM
cool
Aug 18, 2002 12:06 PM
lucas569
Aug 6, 2001 02:14 PM
