compression test question
Old Aug 21, 2005 | 08:55 PM
JDM00SI's Avatar
Default compression test question
sup,
im about to run a compression test on my si, i was wondering how many engine cranks i shall do in order to get good results. i will be removing the spark plugs obviously, and putting the tube down the cyllinder and cranking it. does it matter how many times i crank it or as long as it is the same amount of time on each cylinder?
also do i keep the other spark plugs in as i do each cylinder or should i take out all the plugs and crank it? im thinking keep the other spark plugs in to prevent gas sprays....just want to make sure.
thanks
Old Aug 21, 2005 | 08:57 PM
JDM00SI's Avatar
Default Re: compression test question (JDM00SI)
just bumping it up due to the fact im doing the compression test asap. as soon as i confirm this info.
Old Aug 22, 2005 | 10:43 AM
JimBlake's Avatar
I'd pull some fuses to disable the fuel pump & the spark. Then take all 4 plugs out.
If you wanna count how many cranks, then I guess go 5 or 6. I just keep cranking until the pressure quits increasing.
Old Aug 22, 2005 | 02:32 PM
msmotorsports's Avatar
Default Re: compression test question (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I just keep cranking until the pressure quits increasing.
Exactly! Make sure to open the throttle 100% while cranking.
Old Aug 22, 2005 | 04:37 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I'd pull some fuses to disable the fuel pump & the spark. Then take all 4 plugs out.
That's basically all you need to do.
Old Aug 22, 2005 | 04:56 PM
slomofo's Avatar
GDD Member
Let's see....testing compression, all the plugs will be out.... I don't think the car will be able to start with the plugs out.
Old Aug 22, 2005 | 04:59 PM
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Let's see....testing compression, all the plugs will be out.... I don't think the car will be able to start with the plugs out.</TD></TR></TABLE>
That's the point you don't want the engine to fire up only crank.
Old Aug 23, 2005 | 08:15 AM
mmuller's Avatar
Mad Scientist
Default Re: (Lord Helmet)
you also no not want gas spraying while you crank...
Old Aug 23, 2005 | 10:36 AM
mehdiR's Avatar
Go to http://www.c-speedracing.com/h...t.php
for full procedure.
Old Aug 26, 2005 | 12:44 PM
R-Toyz.com's Avatar
5 cranks
Old Aug 26, 2005 | 05:20 PM
slomofo's Avatar
GDD Member
Compression tests take about five minutes to do on a honda, but for the bench/internet racers.... they gotta make a huge deal about it like it's rebuilding a transmission or something.
jtrig
Honda Civic (2001 - 2005)
Jun 2, 2015 03:55 PM
jt1583
Jun 19, 2005 03:59 AM
zracer240
Apr 24, 2005 08:35 AM
boosted ek
Mar 30, 2005 11:34 PM
Scean
Aug 23, 2004 06:50 PM
