How to CC your engine properly.
Old Nov 8, 2002 | 05:17 AM
Screamer's Avatar
Default How to CC your engine properly.
I have an ITR engine with JE low compression pistons and I would like to find out what is my compression ratio. How can I measure that?
Old Nov 10, 2002 | 08:09 AM
Screamer's Avatar
Default Re: How to CC your engine properly. (Screamer)
Anyone???
Old Nov 10, 2002 | 08:25 AM
Sonny's Avatar
If you know the specs for everything in the engine (like the specifics of the pistons), you can use the compression calculator at http://www.c-speedracing.com
If you want to get an exact number, calculate swept volume (volume of a cylinder) and use a buret with Marvel Mystery Oil to take the volume of the chamber at TDC.
Your compression ratio is (volume of chamber at TDC + swept volume / volume of chamber at TDC)
Sonny
Old Nov 11, 2002 | 05:03 AM
Screamer's Avatar
Default Re: How to CC your engine properly. (Sonny)
thanks for your suggestions, but:
First one I can't do since it requires the piston / deck distance which I am questioning.
Second suggestion sounds a lot better, but could you please explain in more detail the procedure that I would have to go through. Or better yet maybe someone know a web page that goes step by step through this procedure.
Thanks,
Rafal
JarrettL
Honda S2000
Jun 14, 2012 03:09 PM
greasemonkee
Apr 23, 2009 11:40 PM
q8delsol
Sep 22, 2006 01:40 PM
gshockbreaker
Nov 21, 2002 04:16 PM
RiCE On IcE 2
Jul 29, 2002 02:15 PM
