For those engine experts...
Old Nov 19, 2002 | 09:23 AM
gshockbreaker's Avatar
Default For those engine experts...
My car has a D17 engine: 9:9:1 compression ratio and 75x94.4 bore&stroke(mm).
Now, the new civic GX model has a 12:5:1 compression ratio and the same bore&stroke(mm). Can I put those pistons used in GX and replace the ones in my car to UP my compression ratio for better performance??
Old Nov 20, 2002 | 04:33 PM
Simple's Avatar
Default Re: For those engine experts... (gshockbreaker)
gx? whats a gx? and d17? are these newer model civics and engines?? like 2001 and up?
Old Nov 20, 2002 | 05:19 PM
texan's Avatar
Default Re: For those engine experts... (Simple)
It's their new CNG vehicle.
And to answer the original question, if you want to run that high of a compression ratio on your motor reliably you'll need more than just the pistons. Compression ratio in and of itself actually dictates quite a little bit about how other parts of the motor (such as the combustion chamber and camshaft profiles) should be designed, and vice versa. The whole top end needs to be optimized for such a large jump (2.6 points) in compression in order to work reliably and effectively.
Old Nov 21, 2002 | 03:41 PM
Lousy Beans's Avatar
Default Re: For those engine experts... (texan)
They are also forged
Old Nov 21, 2002 | 04:07 PM
texan's Avatar
Default Re: For those engine experts... (Seth Davis)
forged pistons in an OE application? Are you sure about that?
Old Nov 21, 2002 | 04:16 PM
Doogie Howser's Avatar
yes the Natural Gas civics came with 12.5:1 compression forged pistons and they will fit your d series motor
4genaccordfreak
Apr 30, 2014 06:28 PM
jusholeum
May 18, 2009 01:58 PM
soon2bdropped
Oct 3, 2007 06:28 PM
Tee Jay
Jul 11, 2003 12:10 PM
sushibug
Apr 3, 2002 05:04 PM
