How can i test my oil pump?
Old Feb 1, 2004 | 09:14 PM
Blazeone's Avatar
Default How can i test my oil pump?
I have a used oil pump out of my ITR motor before i rebuilt it and put anotehr OEM in its place. Now i am building up a B18B and i want to be sure that this pump will be ok to use in my new motor(for a LS teggy), is there a way i can test it to see if it will perform well?
Old Feb 1, 2004 | 09:18 PM
boostn420's Avatar
Default Re: How can i test my oil pump? (BlazeONE)
You can take it a part and measure the clearance in the gears and look for scoring on the walls if metal passed through it. The clearance specs are in the manual.
Old Feb 1, 2004 | 09:23 PM
Blazeone's Avatar
Default Re: How can i test my oil pump? (boostn420)
Cool thanks
Is there any place i can find the specific clearances on this, perhaps maybe its just in a helms manual?
Old Feb 1, 2004 | 09:31 PM
boostn420's Avatar
Here's what the manual says.
innet to outer rotor clearnace New .04-.16mm(.002-.006in)
Service Limit .20 (.008)
Pump housing to outer rotor clearance New .10-.19 (.004-.007)
Service limit .20 (.008)
Pump housing to rotor acial clearance New .02-.07 (.001-.003)
Service Limit .15 (.006)
Old Feb 1, 2004 | 11:12 PM
Blazeone's Avatar
Thank you very much, i appreciate all the help
xyk
Jan 6, 2010 08:00 PM
mahatma
May 4, 2006 08:38 PM
jsnm
Apr 20, 2005 08:32 AM
eghonda
Feb 7, 2004 06:03 PM
DOHCarp
Nov 26, 2002 11:02 AM
