how can i convert a obd2 distributor to obd1?
Old Jan 30, 2003 | 12:22 PM
mugenDAxsi's Avatar
Default how can i convert a obd2 distributor to obd1?
Modified by mugenDAxsi at 4:55 AM 4/21/2003
Old Jan 30, 2003 | 01:37 PM
sgT's Avatar
sgT
Default Re: how can i convert a obd2 distributor to obd1? (mugenDAxsi)
just pull the pins out of the obd2 plug and put them in the correct order into
the older plugs. internally they are the same
Old Jan 30, 2003 | 02:46 PM
Malgerus's Avatar
Default Re: how can i convert a obd2 distributor to obd1? (sgT)
Sure it's possible... I was running a D16Y8 (OBD-II) distributor and fuel injectors off of an OBD-I P28.
Old Jan 30, 2003 | 04:37 PM
hybridb18's Avatar
Default Re: how can i convert a obd2 distributor to obd1? (Mr. S)
just cut the obd 2 plug off and match up the wires on the obd1 plug. the only thing different about 0bd2 over obd1 is the ecu
Old Jan 31, 2003 | 11:22 AM
sgT's Avatar
sgT
how much clearer can you get? lol
HamiltonRex
Mar 22, 2005 07:53 AM
speedrcr24
Feb 27, 2005 07:16 PM
