hot start continued
Old Apr 29, 2016 | 11:38 AM
bryondyck69's Avatar
Default hot start continued
So my turbo b18c1 runs mint, but as soon as I shut it off when hot, it won't start for about another 30 min.
Found out there is no injector pulse when hot but when I spray false fuel into turbo it starts and stays running. Distributor has been replaced. Has spark and fuel.
Heard it could be crank sensor?
Old Apr 30, 2016 | 01:40 AM
holmesnmanny's Avatar
Default Re: hot start continued
I would open up the ecu and look for any burned spots. Are you 100% sure there is spark when it's not starting ?
Old Apr 30, 2016 | 02:00 AM
Yeah 100% sure.
Old Apr 30, 2016 | 02:06 AM
I suppose it's possible the main relay is bad. It controls the fuel pump AND the injectors.
Not sure exactly why it would be having issues when you shut her down but this is just a guess.
Old May 1, 2016 | 01:00 PM
fcm's Avatar
fcm
Old Fart
First thing I would check is the PGM-FI Main Relay, it is a cheap easy fix, and they are prone to intermittent problems. 94
Old May 17, 2016 | 05:02 PM
Do you know a good site I could order one off of?
Old May 17, 2016 | 09:47 PM
You can either have someone resolder it or you can get one from rockauto, they use different names for it so look through different options, make sure to google "rockauto coupon code" before buying and plug it into the "how you heard about us" to get a 5% discount.
Old May 18, 2016 | 08:13 AM
fcm's Avatar
fcm
Old Fart
I just repair them or find one at my local PicknPull.
94
Old May 18, 2016 | 08:11 PM
https://www.youtube.com/watch?v=X5Qp-ToR8KA 94
I can't for the LIFE of me find the main relay wtf
Old May 19, 2016 | 07:44 AM
fcm's Avatar
fcm
Old Fart
Should be right above the hood release handle. 94
PG103
Honda Civic (2001 - 2005)
Aug 30, 2018 08:41 AM
harleyjohn
May 9, 2015 03:04 PM
mibayaua
Oct 28, 2012 11:40 PM
gs-R_swap
Sep 23, 2009 07:02 AM
MADEinJAPAN
Sep 27, 2003 09:36 PM
