Hooking Up Timing Light to CDI Setup
Old Feb 2, 2009 | 08:32 AM
LR8G8R's Avatar
Default Hooking Up Timing Light to CDI Setup
I'm changing over to the AEM CDI with the AEM Pensil coils on a Prelude. I need to sync the timing and I wanted to know if I need to make a jumper wire from the bottom of the coil to the plug, or am I overlooking something here? I have set the timing on Nissan SR20's using this method, but I wanted to see if there is another way. Thanks
Old Feb 2, 2009 | 10:04 AM
thesmogman's Avatar
Default Re: Hooking Up Timing Light to CDI Setup
Some inductive pick-ups will pick-up the spark if it is on top of the coil. Some will use the signal/wires to the coil too.
Or you could just cut an end off the old plugwires and use that to make your jumper.
We call this set-up COP (coil on plug)
$MIKE$
Engine Management and Tuning
Apr 28, 2014 03:21 AM
Jmumblez2001
Nov 3, 2006 01:36 AM
rasinhell
May 24, 2005 06:32 AM
conorm
Mar 6, 2002 03:47 PM
