The Blend of Honda MTF
Old Jan 8, 2002 | 07:18 PM
Quick 200k Mile Motor's Avatar
Default The Blend of Honda MTF
Most of us know that it is the best* oil to use in the manual transmission.
Whenever I go to the dealer, they always tell me "Just use Regular 10W30 Motor Oil." I know better than that. I always get Honda MTF now, because from the 3 transmissions i went through, I only found Honda MTF to work better than any other.
Regular Castrol GTX 10W30, too sticky at high temps.
10W30 Fully Synthetic (Castrol & Mobil1) and...
Redline MTF, too slippery caused the synchros to go bad.
Mobil1 Fully Synthetic Gear Oil, very thick oil. Gears grind after first 100miles.
Honda MTF
-Smoother shifting @ low and high temps
-Low Oxidation Rate
-High shear stability
(from the back of bottle )
We know what it is, but what is it made out of?
Is it a pure oil, or Is it a blend? If it is, what blend is it?
Old Jan 8, 2002 | 07:37 PM
DR. ON POINT's Avatar
Banned
Default Re: The Blend of Honda MTF (Quick 200k Mile Motor)
hmmm....honda manual transmissio fluid....nice
Old Jan 8, 2002 | 09:43 PM
nfn15037's Avatar
Default Re: The Blend of Honda MTF (On Point EK)
Its a very highly guarded JDM secret. Only a select few know the true voo doo magic ingredients each bottle of Honda MTF is blessed with.
Old Jan 9, 2002 | 04:48 AM
Mista Bone's Avatar
D Tranny Guru
Scary thing is, the MTF fluid was brought over from the motorcycle division.
I use Honda MTF when racing, or 5w30 when in street form.
I likely change my tranny fluid more often than most people change their engine oil!
Old Jan 9, 2002 | 05:56 AM
Greyout's Avatar
Default Re: The Blend of Honda MTF (Mista Bone)
I'm guessing the dealer sells this stuff?
Old Jan 9, 2002 | 06:20 AM
Crazydave's Avatar
Default Re: The Blend of Honda MTF (JDM LUDE)
my local dealer never has it in stock
[Modified by Crazydave, 7:20 AM 1/9/2002]
Old Jan 9, 2002 | 06:25 AM
Spade's Avatar
Default Re: The Blend of Honda MTF (Crazydave)
Crazy, drive up to Carlsbad......Hoehn Honda has boxes of the crap in stock usually.....just make sure I haven't gone there first.
Old Jan 9, 2002 | 08:38 AM
rioninja's Avatar
I've heard that its just straight synthetic 30 weight.
Whatever it is, is does work good
Old Jan 9, 2002 | 09:17 AM
seek167's Avatar
Default Re: The Blend of Honda MTF (RioNinja)
group buy in the type r fourm right now i think 44.00 a case shipped
Old Jan 9, 2002 | 09:20 AM
Crazydave's Avatar
Default Re: The Blend of Honda MTF (Spade)
hehe.... I'm pissed I dumped a bunch of tranny fluid when I pulled my motor... then pacific honda didn't have any mtf...
Old Jan 10, 2002 | 03:30 AM
Mista Bone's Avatar
D Tranny Guru
Word of note after draining Honda MTF.
Dump the drain pan of MTF into a closed container. If left in the drain pan over night, whole house will smell like MTF in the morning!!!!!!!!
You only make that mistake once!
Old Jan 10, 2002 | 06:20 AM
Jesse H's Avatar
and that's a bad thing?
Old Jan 10, 2002 | 09:20 AM
J T*'s Avatar
Default Re: The Blend of Honda MTF (Jesse H)
just curious because i always use Honda MTF but have gone through 3 trannys on my old D16 (road racing) and everytime iv'e gone to a shop they always tell me to just use 10w-30 motor oil. I don't because the manual says only use Honda MTF but I'm just wondering why everyone tells my not to use it.
Old Jan 10, 2002 | 02:22 PM
Default Re: The Blend of Honda MTF (50percentRice)
The parts guy at the Honda dealer told me that the mechanics out in the shop actually use Regular 10w-30 motor oil for the manual transmissions. Honda MTF is very expensive. They are trying to keep the costs down of oil changes. They have never used Honda MTF out there unless the costumer requests it.
Chiltons and other aftermarket manuals recommend motor oil.
From Chiltons: "10W-30 or 10W-40 viscosity; the 10W-40 is the safer recommendation, especially when driving is at high speeds for long periods in hot weather."
I only use Honda MTF now. Its stays clean longer (low oxidation rate). Not sticky or slippery at low or high temps.
Grinding gears.. Its easy to grind gears. Even in a new car (damn Si).
I recommend using a short M14-1.50 Oil drain plug with Magnetic Rod for the drain holeoin the tranny. It will keep some of the shavings from circulating in the system (drain plug must be short for clearance).
Old Jan 10, 2002 | 07:25 PM
Disco Monkey's Avatar
isn't mtf the worst smelling stuff! i changed mine recently and man did it stink...id hate for my whole house to smell like that...
Old Jan 10, 2002 | 07:33 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: The Blend of Honda MTF (Disco Monkey)
i will soon find out this 'mtf' scent.
Old Jan 11, 2002 | 10:59 AM
Rogue108's Avatar
Its just oil...Use dinosaur 10W30 and you will be fine. Don't believe the hype
lordbucanero
Transmission & Drivetrain
Jan 27, 2012 08:52 AM
Mashka
Honda S2000
Sep 3, 2007 01:50 PM
JDR
Jan 7, 2007 02:22 PM
raene
Nov 23, 2002 01:11 AM
91DA9
Dec 15, 2001 11:08 AM
