compression ratios.
Old Nov 20, 2006 | 05:49 PM
jikespingleton's Avatar
Default compression ratios.
im gonna build a n/a b18c. with 91 octane, how high of a compression ratio can i run?
Old Nov 20, 2006 | 06:26 PM
iH8RICERZ's Avatar
Default Re: compression ratios. (jikespingleton)
depends....daily/street driven or for track? modifications you plan to go with? Tuning will be key if you go low or high compression.
Old Nov 20, 2006 | 07:03 PM
95 integra's Avatar
Default Re: compression ratios. (iH8RICERZ)
Depends on alot of factors....what cams are you going to run? OEM or aftermarket pistons?
Old Nov 20, 2006 | 07:37 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: compression ratios. (95 integra)
+1 for tuning making or breaking it if you want to go high comp N/A...
use this to calculate your ESTIMATED compression then go from there.... http://www.zealautowerks.com/
i would personally try to at least run 93 octane gasbut when you get over 11:1 you might want to think about tuning and higher octane gas
Old Nov 20, 2006 | 07:48 PM
DS002's Avatar
Banned
Default Re: compression ratios. (GRAF-FITI)
ITR pistons call it a day
Old Nov 20, 2006 | 08:05 PM
DB1_559's Avatar
c-speedracing.com
Old Nov 20, 2006 | 08:06 PM
Default Re: compression ratios. (DS002)
out of curiousity how much do itr cams cost?
Old Nov 20, 2006 | 09:34 PM
DaTeggy92's Avatar
itr cams average anywhere from 300-400 bucks depending on who and where you get them from. also, if they are used or brand new would be a factor.
Old Nov 20, 2006 | 10:04 PM
Spectrum24x's Avatar
Default Re: compression ratios. (DaTeggy92)
I'm assuming the question wasn't what will my compression be, its what kind of compression is streetable right?
Well, as said before, its all in the tuning...
I'm runing 12.7:1 compression on the street with 93 octane, daily driven never had a problem.. i've heard of cars running in the mid 13 compression areas.. so like said before, its all in the compression..
But the key to high compression is good cams, with high compression when you make things flow better, you see bigger results
Old Nov 21, 2006 | 09:02 AM
95 integra's Avatar
Default Re: compression ratios. (Spectrum24x)
Also note.....dynamic compression will depend on the cam choosen and will have atleast some small part to do with whats streetable.
realis9
Mar 5, 2007 10:22 PM
crampinyourstyle
Jul 19, 2006 10:59 PM
limpy
Jun 27, 2005 01:04 AM
spooncivic1
Dec 20, 2004 06:44 PM
Mad Cow Disease
May 20, 2004 11:30 AM
