1984 CRX engine problem, won't start
Old May 25, 2003 | 07:13 PM
Jeff C's Avatar
Default 1984 CRX engine problem, won't start
The engine appears to have gotten hot, and had a blown radiator hose. I was told it had a blown head gasket but found that not to be the case. I have had the head checked with new valve seals installed. Everything is at tdc and the rotor is pointing to the #1 sparkplug. I am getting spark and fuel. A cooling system pressure check slowly looses pressure, but I cannot hear or see any leak even with the plugs pulled.The engine will not fire. It sounds like it wants to. I can hear popping in the carburator.
Old May 25, 2003 | 07:32 PM
poison's Avatar
Default Re: 1984 CRX engine problem, won't start (Jeff C)
What are the compression results?
Do a complete compression check and make sure it holds the PSI to it's peak. If it's losing pressure, then your valve seals are bad, headgasket is bad or not properly installed.
Some sort of compression is coming out and is not enough to make a complete power stroke.
HTH.
Old May 29, 2003 | 01:14 PM
Jeff C's Avatar
Compression reads 140-135 across the cyclinders. It is so close to starting, but just cant make it over the hump. We did drain the oil and it was watery so that must mean a cracked water jacket, oh well. I think that we are going to get another motor.
Old May 29, 2003 | 01:15 PM
poison's Avatar
sounds like the problem.
she wants to start but just isn't turning over. with one of the water jackets cracked, the motor will not last long anway. I'd get yourself another motor as well.
good luck man
Old May 29, 2003 | 01:19 PM
Jeff C's Avatar
Default Re: 1984 CRX engine problem, won't start (poison)
Would a crack water jacket keep it from starting?
Also, you don’t happen to know whether the 84 head would be compatible with an 88dx block, do ya?
giovannie23
Jun 4, 2015 07:02 PM
gowenburnett
May 31, 2011 03:05 PM
honda_prelude_jay
Jan 3, 2009 03:36 PM
hmtcrxsir
Jul 10, 2007 10:06 AM
Tomsecks
Nov 12, 2005 11:57 AM
