high flow cats? do they work
Old Nov 8, 2002 | 08:01 AM
jeddy0120's Avatar
Default high flow cats? do they work
what up me and my friend were having a discussion about putting a header on my car and i said i was going to install a high flow cat as well. So he says my dad did a test on them and says they dont work.
Is this true?
i keep telling him that there is no way that it is true. Just thinking about it logically should tell u that it works. Having the same amount of free flow throughout the system should benefit the engine the most right?
What do u guys think?
Old Nov 8, 2002 | 09:46 AM
PissAnt's Avatar
Default Re: high flow cats? do they work (jeddy0120)
Do they work? yes they flow better.
Do they free up HP? maybe 0-1 HP at best but in some instances could lose HP because it can slow down your exhaust velocity.
Old Nov 8, 2002 | 09:49 AM
anjapower's Avatar
Default Re: high flow cats? do they work (PissAnt)
Slowing down exhaust velocity should only happen if the high-flow cat ID was too large. Going from 2.0" inch exhaust system to a 2.25" or from a 2.25" to a 2.5" shouldn't warrant a loss in HP.
Old Nov 8, 2002 | 10:01 AM
raene's Avatar
Default Re: high flow cats? do they work (anjapower)
I think the gains are more as in cases like mine, where the cat is a smaller diameter than both the piping entering from the collector and exiting from the cat
Old Nov 8, 2002 | 10:33 AM
anjapower's Avatar
Default Re: high flow cats? do they work (raene)
That's what jeddy wants to do. He's going to be buying a header, and already has an exhaust. I told him he should buy a hi-flow cat as well if he plans to get a header. But another friend of ours said that there's no need, as it wouldn't help him at all.
Although the gains will be minimal, if you're gonna do I/H/E, you might as well do hiflow cat.
Old Nov 8, 2002 | 02:21 PM
10K2HVN's Avatar
2 WORDS...
STRAIGHT PIPE...
Old Nov 8, 2002 | 02:23 PM
10K2HVN's Avatar
Default Re: high flow cats? do they work (10K2HVN)
oh yeah dont forget to get mendrel bent piping...
or just run a test pipe...
Old Nov 8, 2002 | 03:04 PM
976's Avatar
976
New User
Pretty much everthing is covered. Now search and learn the backpressure theroy. No need to start new, a lot of good info acrhived.
Dylanamus
Nov 23, 2006 08:43 PM
wakethatassup
Nov 6, 2003 09:40 PM
[DIGGA]
11
May 9, 2003 11:52 AM
1fastGSR
Aug 21, 2001 10:55 AM
Brad
Jul 10, 2001 12:06 PM
