which will give the most hp?
Old Jul 10, 2001 | 11:29 AM
Brad's Avatar
Default which will give the most hp?
Currently I have a 60mm trust exhaust with a 2.5" down pipe with no cat. I was wondering if going to a 3" exhaust and down pipe with a 3" carsound cat would gain or lose horsepower seeing as a cat would restrict exhaust flow? This is for a t3/t4 turbo b18c.
thanks,
Brad
Old Jul 10, 2001 | 11:44 AM
b18bturbo's Avatar
Default Re: which will give the most hp? (Brad)
the 3inch exhaust with 3inch dp and car sound cat should give you the extra hp. it all depends on if you run low or high boost. tooo
Old Jul 10, 2001 | 12:04 PM
Brad's Avatar
Default Re: which will give the most hp? (b18bturbo)
would the 3" set up be good for 8-9 psi, or would that be on the low side?
thanks.
Old Jul 10, 2001 | 12:06 PM
FAST94GSR's Avatar
New User
low side but still would yield gains. Turbos like a non restrictive exhaust. the freer the flow the more hp and the faster it will spool up.
Bnjmn
Nov 14, 2003 06:48 AM
wakethatassup
Nov 6, 2003 09:40 PM
2000GSRT
Jun 25, 2003 09:56 AM
blackteg
Jun 17, 2002 03:22 PM
1fastGSR
Aug 21, 2001 10:55 AM
