hesitation after obd0-obd1 conversion
Old Aug 23, 2006 | 05:47 PM
  #26
mtber's Avatar
Default Re: hesitation after obd0-obd1 conversion (jakscivic)
I doubt the issue is the ecu, but you are more then welcome to send the ecu back to have it tested using a wideband oxygen sensor to ensure the ecu is working properly.
(I would install one ecu and monitor the a/f ratios then install your ecu with the same program and monitor the a/f ratios etc.)
Old Aug 23, 2006 | 06:34 PM
  #27
jakscivic's Avatar
The cat should be in good condition. I doubt its the ecu either. But the itr chip had a dramatic improvement over the other one. But once I get to portland i will try out my friends obd1 ecu again and drive around a little and see if it drives the same or if it works perfect. If it does then I will send it back to you guys to check it out. Im also hopeing that the header will get here before the track so i can see if it might be my o2 sensor not being in or something.
EFinAwesome
Jul 21, 2012 11:02 PM
dbiker207
Apr 21, 2007 10:23 PM
dbiker207
jakscivic
Sep 10, 2006 06:57 PM
Cprace1
Nov 18, 2005 03:41 PM
