Help with y8 intake manifold swap please
Old Jan 28, 2003 | 03:03 PM
buskethead's Avatar
Default Help with y8 intake manifold swap please
Ok, I think I have everything hooked up correctly so far, but I have one connection that I can't figure out where its supposed to go. It is the hard line that is connected directly below the line that goes from the valve cover to the intake. The end that has the hose that goes down to the block is connected, but there is no hose connected on the part of the hard line that points towards the driver side of the car. So I am just trying to figure out where I am suppsed to connect this to. Is is a coolant line? or just a vaccum line?
http://www.makuragi.s5.com/civic_99/...m%20source.jpg
Also, in this picture, I just have the evac/purge vaccum source plugged because I think I Just used the cruise control vaccum source on the back of the manifold for that thing. But I may be mistaken. I am still very confused about which sensors/valves are what.
If anyone could help me out a bit here it would be very greatly appreciated. Or if you could just point me towards somewhere that I could see some pictures or something.
thanks in advance
Old Jan 28, 2003 | 09:26 PM
buskethead's Avatar
Default Re: Help with y8 intake manifold swap please (buskethead)
Still need some help guys I am pretty sure that this hose used to go to a coolant connection that sticks straight up from just to the left of the intake runner that is farthest to the passenger side (real close to where the intake mani bolts to the head). But on the y8 intake manifold there is no connection like this. So where the heck am I supposed to run this hose to?
Old Jan 29, 2003 | 07:25 AM
tmg's Avatar
tmg
i can't exactly make out what you're saying. is this manifold a y8 mani? if not there will be an extra vacuum hard line that you can just plug. the y8 only has about two or three vaccum lines on the mani. i don't have my y8 but i think there's only two.
Old Jan 29, 2003 | 07:35 AM
tmg's Avatar
tmg
the cruise control uses a bottom line in the back of the mani that goes up and connects with a t valve on the driver's side (right). those are all vacuum lines. the only coolant line you have is on the left side of the mani and it's bigger than the vac ones.
Old Jan 29, 2003 | 08:26 AM
brcivic411's Avatar
Default Re: Help with y8 intake manifold swap please (themi6group)
I responded to your other post about the sensor.
The 'hard line' you're talking about, is it not connected to anything? ie, both ends of the line are disconnected?
If they are, then I think it's what connects the valvecover vent to the intake tubing.
If one side is connected, follow to see what it's source is.
Old Jan 29, 2003 | 08:29 AM
buskethead's Avatar
yeah, this is a y8 intake manifold going onto a d16z6 engine/head. And I don't have cruise control, just to clarify that. I think I have the sensor thing kinda figured out. But I am still trying to figure out what to do with this extra coolant line. It basically runs from the back of the head or block (can't see it real well) back up and runs underneath the breather line that goes from the valve cover to the intake arm. Then on the z6 manifold, it went to a coolant connection that stuck straight up just to the left of the runner farthest to the passenger side of the car. On the y8 manifold, there doesn't seem to be a third coolant connection like this. There is only the larger connection, and the one that comes off at a right angle from that.
I'll see if I can't find some pics to kinda try and expain myself better, but I don't have a digi cam...so I'll see what I can come up with
thanks again for the help
Old Jan 29, 2003 | 08:32 AM
buskethead's Avatar
actually, this is the line that is just right below the valve cover breather line. The one end hooks into what I would guess would be the head maybe, right under the intake manifold. It is right next to a couple of other larger what I am assuming are coolant lines.
*EDIT* I just found some pics of a z6 manifold, I am working on chopping them to show you guys what I am talking about. Pics should be up in like 10-15 mins
[Modified by buskethead, 9:36 AM 1/29/2003]
Old Jan 29, 2003 | 08:52 AM
buskethead's Avatar
Ok, here is the pic I found....
So, the red line is the main coolant line that circles back down and connects to the same thing that the lower radiator hose is connected to. The blue line is from a coolant connection that is kinda hidden, and that runs to the sensor/valve thing right under the throttle body. Then the green line shows how the coolant line is supposed to go from that connection, up to the hard line that is connected right under the breather hard line for the valve cover, and then it goes down and connects in just to the left of where the red line goes.
Old Jan 29, 2003 | 09:04 AM
tmg's Avatar
tmg
ok, i see that extra line you are talking about. it is basically "t'd" off of the coolant bypass line, that's why you see three lines and two ports on the z6 mani. it shoots straight up while the coolant bypass line curves around back to the block. you need the "t" connector that intersects the coolant bypass and the other hard line which meets at the manifold.
[Modified by themi6group, 1:05 PM 1/29/2003]
buskethead's Avatar
here is the y8 intake manifold (got the picture from http://www.makuragi.s5.com/civic_99/Y8maniswap/ hopefully they won't mind)
So, the red line is hooked up, and the blue line is hooked up, but there is no place for where the green line is supposed to hook up to. Hopefully this makes sense.
*EDIT* ok, I think I see what I need to do now, I am just going to tee this line into the larger hose that runs to the back of the engine. Thanks a ton for your help! I very much appreciate it!
[Modified by buskethead, 10:08 AM 1/29/2003]
Old Jan 29, 2003 | 09:08 AM
tmg's Avatar
tmg
there is no green port on the y8. the red and blue take care of the job so there is no need for the green. the z6 needed the green because the bypass hardline was only a one port.
Old Jan 29, 2003 | 09:10 AM
buskethead's Avatar
Oh, hmmmm, so, do you think I can just cap that third line off at the block? or should I still try to tee it into the other coolant line?
Old Jan 29, 2003 | 09:17 AM
tmg's Avatar
tmg
uh, not sure. i don't have a my y8 anymore so it's difficult for me to tell you. inspect those lines very well and if it isn't needed then give it a try. you should be fine.
Old Jan 29, 2003 | 09:32 AM
buskethead's Avatar
hehe, thats cool, I think I am just going to tee it into the other coolant line. I think it should work out ok. I'll be back in a bit, gotta run to the store to get me some fittings
thanks again
Old Jan 29, 2003 | 01:41 PM
Pengo's Avatar
lemme know what kinda improvements u feel when u get this thing running. i'm wondering if i should get a y8 manifold for cheap for wait for skunk 2 or edelbrock to finally release theirs.
Old Jan 29, 2003 | 02:36 PM
pornstarSR's Avatar
ok im not sure if this is gona answer the question...but what i think your asking is where to the 2 brass hose connections on the manifold hook up too.
the bottom one hooks to the Pcv hose coming off the block......the top one is for the brake booster..
not sure if this help cause i wasnt sure what the question was
Old Jan 30, 2003 | 07:31 AM
buskethead's Avatar
Default Re: Help with y8 intake manifold swap please (pornstarSR)
Ok, well, I got everything hooked up and working right. The old butt dyno is kinda hard to judge right now because I have been driving around my parents truck for the last 3 days, so anything feels like a rocket compared to that. But it still feels like it pulls a bit harder, especially in 3rd and 4th. I'm going to have to do some more testing but I really felt VTEC kick in pretty good in first gear when I got to drive around for a bit.
So, this took me for friggin ever to do, but it was fun and gave me a lot more knowledge about my car, and how to improvise and not screw things up. I give it a
Thanks very much for your help again guys!
*EDIT* I think this is a very worthwhile upgrade, especially if you already have i/h/e and what not. Just because if you do everything yourself, and you find a good deal on everything (I got my complete intake manifold for $80) its pretty cheap over all. It's a lot of work, but I'm pretty sure that my situation was an exception.
[Modified by buskethead, 8:34 AM 1/30/2003]
Old Jan 30, 2003 | 07:36 AM
tmg's Avatar
tmg
no prob if i was of any help, sounds good man
Old Jan 30, 2003 | 08:25 AM
brcivic411's Avatar
and while the Intake manifold is off.. might as well replace the gasget with hondata's IM gasget.
and while the intake manifold is off.. might as well install that 3rd motor mount bushing...
and while the intake manifold is off.. do a nice port/polish job with your dremel..
it never ends
Old Jan 30, 2003 | 10:21 AM
teal_dx's Avatar
hey i read this post too late, but I put a 99 Y8 mani and head on my 92 dx d15b7. I have alot of pics of the details, lemme know if you need any help. BTW, I also got a plastic T splitter from home depo for the coolant line situation, no problems!
Old Jan 31, 2003 | 07:50 AM
buskethead's Avatar
Default Re: Help with y8 intake manifold swap please (brcivic411)
it never ends
So true. I wish I had the time and money to do all that this time, but I'm sure I'll be pulling everything apart again sometime soon
Yeah, I used a little plastic T from kragen, and it seems to be doing just fine. The only thing I still really need to do is figure out where to mount the "purge control solenoid valve" (that's what my helm's manual calls it), just so that it is not so ghetto and zip tied on there, hehe
Now I just have to start saving up for a nice junkyard turbo setup! YAY!
[Modified by buskethead, 8:52 AM 1/31/2003]
Old Mar 18, 2003 | 11:22 PM
stockgreencivic's Avatar
bringing back old post,,,
buskethead,
do you have any pictures of your swap? how hard was this to do?? any tips or tricks? worth while?
anyways, get back to me if you can.
Old Mar 19, 2003 | 12:52 AM
7PSI CRX's Avatar
Default Re: Help with y8 intake manifold swap please (stockgreencivic)
Don't know if it'll help ya, but here's some pics of a stock Y8 intake manifold:
http://server35.hypermart.net/heyriz...ics/Eng006.jpg
http://server35.hypermart.net/heyriz...ics/Eng007.jpg
http://server35.hypermart.net/heyriz...ics/Eng016.jpg
http://server35.hypermart.net/heyriz...ics/Eng019.jpg
[Modified by 7PSI CRX, 5:01 AM 3/19/2003]
EG-SIXV-TEC
Feb 25, 2010 05:56 PM
agy2k2
Aug 11, 2006 05:30 AM
93sleeper
Mar 22, 2005 01:50 PM
buskethead
Jan 30, 2003 12:05 PM
TurboIntegra
Jul 11, 2001 09:42 PM
