Help with wiring gremlin (short)
Old Sep 16, 2013 | 03:58 PM
SiRCiviC94's Avatar
Default Help with wiring gremlin (short)
I can't get this one. Car is losing voltage every where when the ignition is in ON position. ACC voltage everywhere is steady 12.5 ish. When its at the ON position voltage is 12.1 and dropping at battery and 11.95 and dropping at ignition switch.
The car runs if jump started, the car will not start only click and then it won't even click since voltage is getting low? I have this issue intermittently since a new swap was installed. So it has started on its own since the swap many times....
I am great ful for all help thx!
Old Sep 16, 2013 | 04:00 PM
SiRCiviC94's Avatar
Default Re: Help with wiring gremlin (short)
As well all grounds have been gone over and cleaned valve cover tranny and battery. Fuel primes every time till power is nearly lost and every time I click the starter the gauge lights dim more.
Old Sep 19, 2013 | 06:38 AM
fcm's Avatar
fcm
Old Fart
It is a connection problem, most likely a grounding issue, you mention "valve cover tranny and battery" but not the chassis ground. 94
Jmx305
Mar 20, 2015 05:29 AM
SuckItNerd
Feb 5, 2015 04:47 PM
ITR32
Apr 7, 2007 09:28 AM
swatteamtimmah
Mar 3, 2006 02:23 PM
onefastegg
17
Aug 20, 2004 05:49 AM
