!!! HELP!!! tranny problem
Old Mar 9, 2004 | 04:48 AM
brx017's Avatar
Default !!! HELP!!! tranny problem
Let me explain what happened from the beginning, maybe that will help. Sunday I noticed my pedal felt different. It wasnt smooth like it usually is, and there was slop/slack before it felt like it was engaging. Also I had to push it all the way to the floor before it would go into neutral (which usually isnt the case). Then probably 5 or 10 miles down the road I started to hear a WHIRRRRRRR kind of noise between 2nd and 3rd (syncros maybe?). Then this morning on the way to work, it started acting like my clutch wasnt engaging hardly at all. It was revving like i was in neutral and just barely going. I turned around and started heading home. I noticed that if I barely accelerate, it goes, but if i dont its like the clutch is slipping. any ideas. By the way I made it home, just slowly. and I never smelled the clutch.
Thanks in advance, Brooks
Old Mar 9, 2004 | 07:11 AM
brx017's Avatar
bump
Old Mar 9, 2004 | 07:23 AM
Dan GSR's Avatar
Default Re: !!! HELP!!! tranny problem (brx017)
time for new clutch/pressure plate
sounds like yours isn't grabbing
Old Mar 9, 2004 | 07:48 AM
Noe Kozz's Avatar
Default Re: !!! HELP!!! tranny problem (Dan GSR)
Do you have fluid in your reservoir? Have you tried bleeding your clutch?
Old Mar 9, 2004 | 07:50 AM
Dan GSR's Avatar
Default Re: !!! HELP!!! tranny problem (Noe Kozz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noe Kozz &raquo;</TD></TR><TR><TD CLASS="quote">Do you have fluid in your reservoir? Have you tried bleeding your clutch?</TD></TR></TABLE>
bad/low fluid or bad m/c won't make the clutch slip
Old Mar 9, 2004 | 08:42 AM
brx017's Avatar
The fluid is full. Guess I'll just park it a week or two until I can get my B18C5 and tranny put in. I thought maybe there would be some quick fix I could do so I wouldnt have to borrow someones car. Oh well, thanks for the help.
xintegr
Mar 27, 2006 07:37 PM
SHREK3D
May 17, 2005 06:12 PM
VTECRaZeR
May 30, 2003 11:10 PM
onyx00
Sep 20, 2002 10:06 AM
