car problem
Old May 14, 2005 | 08:16 AM
SHREK3D's Avatar
Default car problem
ok i have a 94 integra rs..heres the deal when i try to shift gears it gets stuck like it doesnt want to go in gear...i have to basically force it into gear...but now whenever i take off in first my car jerks like something is not catching...what could be the problem? tranny fluid? clutch? or just the damn tranny...your help is needed cause its pissing me off...
Old May 14, 2005 | 09:31 AM
TurboGS-R's Avatar
Default Re: car problem (SHREK3D)
Sounds like the clutch to me, but get some other opinions too....
Old May 14, 2005 | 01:44 PM
ckyguy's Avatar
could be anything clutch related, doesn't sound like the clutch itself though. Might be a bent pressure plate or worn throwout bearing. Sounds like something isn't engaging/disengaging properly.
If your clutch pedal feels different at all you might need to fill the resevior and bleed it from having air in the lines, that happened to me last winter and I had the same things happen, but you didn't say anything about your clutch feeling different so it might be the first couple things i mentioned.
Old May 14, 2005 | 02:02 PM
ALMXDUPINTEGRA's Avatar
Clutch sounds done
Old May 14, 2005 | 02:54 PM
jaydeemmmm's Avatar
Sounds like clutch or possible synchro problems. Is your catch point on the clutch high up? If your clutch is starting to slip, it then you might want to change it.
Old May 15, 2005 | 07:19 AM
SHREK3D's Avatar
ive been thinking its everything you guys are saying...the clutch doesnt slip it just doesnt want to go into gear...until i force it into gear...and sometimes my clutch pedal shakes a little when i have it in neutral
Old May 15, 2005 | 07:53 AM
yrethguad's Avatar
Default Re: (SHREK3D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHREK3D &raquo;</TD></TR><TR><TD CLASS="quote">ive been thinking its everything you guys are saying...the clutch doesnt slip it just doesnt want to go into gear...until i force it into gear...and sometimes my clutch pedal shakes a little when i have it in neutral</TD></TR></TABLE>
Sounds like clutch to me. Something similar to what happened to me and countless others. This will be the third thread I have posted this pic. Notice the spring is out and it scraped against the diaphragm spring on the pressure plate. It doesn't slip, but rather doesn't seem to want to let go. Clutch pedal shaking is nutz. That means the diaphragm spring is pushed back far enough to bridge the gap to the throwout bearing, which pushes on the arm that pushes on the slave cylinder, which pushes the fluid up to your clutch master to your pedal. At least I'm assuming. Which once again sounds like the same spring predicament. Spring may be lodged, and pushing the diaphragm. Again, see pic.
You should change the clutch ASAP! Driving like you are now is putting a lot of wear on your synchros (forcing into gear), which you don't want to do. You will miss non-crunching shifts. I know I do.
Old May 15, 2005 | 07:54 AM
yrethguad's Avatar
https://honda-tech.com/zerothread?id=1237365
Old May 15, 2005 | 07:57 AM
yrethguad's Avatar
Default Re: (yrethguad)
https://honda-tech.com/zero...92730
Hope this helps.
-James
Modified by yrethguad at 12:17 PM 5/15/2005
Old May 15, 2005 | 07:58 AM
sabotage7's Avatar
Default Re:
i would think its the clutch, sounds like how mine was acting just before my clutch totally went out. when we changed it, one of my springs on the disc was screwed up like in yrethguads pic.
Old May 15, 2005 | 10:58 AM
SHREK3D's Avatar
thanks alot for the info....seems like im getting another clutch then...but which one should i get im thinking maybe exedy stage 1 or 2
Modified by SHREK3D at 8:37 PM 5/15/2005
Old May 15, 2005 | 11:22 AM
WhiteGSR95's Avatar
if its on all gears, ur gonna need a clutch soon
Old May 15, 2005 | 11:49 AM
95gsrturbo's Avatar
Default Re: (WhiteGSR95)
does it grind when it finally goes in?? what gears? all?
my guess = synchros
or the pic above = broken clutch spring
Old May 15, 2005 | 12:18 PM
WhiteGSR95's Avatar
i just read the part about it being jumpie when u get the car going. u need a clutch job. in a few days when ure at a stop its gonna become a bitch to put it in 1st
Old May 15, 2005 | 12:38 PM
91DA's Avatar
change ur clutch
Old May 17, 2005 | 06:12 PM
eghatch02's Avatar
good bye clutch
4everVtec
Jul 26, 2008 10:40 AM
TigerLy
Jul 16, 2008 01:59 PM
zeroz
Aug 29, 2005 05:16 AM
tianporn
Nov 5, 2004 12:18 PM
