HELP!!! skunk 2 manifold problem
Old Apr 18, 2005 | 07:17 PM
starbury's Avatar
Default HELP!!! skunk 2 manifold problem
i put a skunk 2 mani on my 2000 si, when i start it up it idles at 2 and then when it warms up it starts constantly reving up and down at idle i was gettin a check engine then i put in a type r ecu and it was ok and then later on when i started it again it the check engine came on and and it started sputterin and no throttle response my friend switched 2 vacuum lines and the sputterin stopped and the check engine went away but now its back and it still revs up and down.with the type r ecu it throws a 71 code and with the si ecu it throws a 7 so i have NO idea what is going on someone PLEASE help
Old Apr 18, 2005 | 09:39 PM
Typerhead111's Avatar
Default Re: HELP!!! skunk 2 manifold problem (starbury)
you need to make sure the throttle posistion sensor has right voltage and check lines again and again!!
Old Apr 18, 2005 | 10:53 PM
PrettyLude's Avatar
if it warms up and then you have the hunting idle, its the fast idle thermal valve, it just needs to be adjusted
jboogiebrown
Feb 18, 2006 02:35 AM
sleepyeg6
Aug 27, 2005 02:29 PM
starbury
Apr 17, 2005 07:25 PM
AcCoRdStReEtRaCeR
Jan 30, 2003 08:08 PM
CivicSiR7
Jan 17, 2003 08:42 AM
