Help with replacing distributor rotor
I took the distributor cap off. The hole where retaining screw holds the rotor is covered by plastic leak cover.
What’s the correct way to remove the distributor rotor?
Thanks in advance
Thanks in advance
Or go an easier way... mark where your distributor's set at so you know what the timing is.
Find the three bolts securing the dist, and remove it.
Rotate the shaft by hand to access the screw on the side holding the rotor on.
That way, you won't beat your starter trying to microrotate the rotor...
Sensor wiring harnesses need to be disconnected too.
Just make sure you get the distributor keyway orientation back onto teh intake cam correctly. Don't force it...it should just slide on without much of any effort.
need help again.. could not finish it that day.. had to wait until today.
Just turned the rotor so I can see the screw, but its too tight and I don't want to force and brake something.
Is there only one way to remove it properly? - taking the screw out first? or it pops out?
zairas
Oct 19, 2009 03:08 PM
beanwagon
Aug 3, 2009 02:57 PM
What HXMan said. Lightly crank ur ignition until the screw is accessable through the hole.
