Help Please!!
Old Mar 13, 2007 | 06:03 AM
grizzy225's Avatar
Default Help Please!!
Recently put in some arp head studs. I did the timing lined it up with 18* using the mark on the block. When i drive the car from idle to about 2-2500rpm cars smooth sounds good, then from then on seems to be gargly sounding (think its from the intake) and feels like im pulling a house behind me. Also theres a wire that comes off from the main harness, it splits and one goes into the top of the drive side part of the intake(its white) while the other attached connector isn't pluged into anything. I looked and looked and found nothin to put it in, mabye its in a weird place. Also theres a wire coming from the block.. its from a senor with a single wire coming from it that has a circle end that im not sure where it goes.
If you dont understand this cuz i can see wut im talking about and you cant let me know and ill try to reword it.
AIM: grizzy225
Thanks
-Steve
Old Mar 13, 2007 | 03:26 PM
grizzy225's Avatar
Default Re: Help Please!! (grizzy225)
no check engine light jdm b16 p28 ecu not sure if its obd1 or 2.. cars a 92dx.
dreed2300
Jan 21, 2006 06:39 PM
ivanson
Dec 3, 2005 11:12 AM
Blanket Jackson
May 26, 2005 03:21 PM
gritsak
Aug 19, 2003 12:00 AM
Infinity_Racer
Mar 13, 2003 10:08 AM
