help on OBD0 TO OBD1!!!!
ok, just need to get this verified, i am puttin a 92-93 sir ver2 into my 1990 crx, is it true that all i have to do to make it work with a obd0 is to, use a obd0 intake manifold/throttlebody, distributor, and ecu, along w/the obd0 wiring for a b16? someone told me thats it, i had a 1st gen b16 in it, but engine blew, now have this new engine coming, so i already have the obd0 manifold, dist, ecu,wiring, would this work?
Should work.. The motor doesnt know what obd is running it and the obd0 ecu and wiring doesnt know what motor its powering.. I was running a 93' d15b7 motor on an obd0 pm6 ecu for a while and it worked great..
Opps.. forgot to add.. I was also using an obd1 intake manifold, throttlebody, and map sensor.. I dont know anything about the sir v2 motor and what you can use on it.. I just know what I used on my d15 motor..
crazyef8
10
Apr 20, 2009 09:44 PM
