HELP no oil pressure
Old Nov 11, 2002 | 06:22 PM
EG*MonKEY's Avatar
Default HELP no oil pressure
things done to the engine ///help i have no oil pressure...
1....head has been taken to machine shop ...bead blasted...helix coiled some threads...
2..block removed checked bearings with plastic guages.....
3.oil pump and sensor replaced....
4. at idle only about 2-3 psi is present of oil pressure
5..crank...everything seems to be fine.. oil passages seem flowing fine..no leaks visible to eye...
6...the cam lobes have some wear im guessing because little oil is getting to the head....
7....i need ur help
Old Nov 11, 2002 | 08:24 PM
EG*MonKEY's Avatar
Default Re: HELP no oil pressure (EGDrifter)
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 11, 2002 | 11:14 PM
kinesistech's Avatar
Is it possbile that the gauge reads bars instead of psi? Cause if it were 30-45 psi at idle that would be fine.
Old Nov 12, 2002 | 08:22 PM
InevitableRace's Avatar
first of all...What kind of motor???
and what did you do to it???
Thanks
Ross
joshledbetter12
Jan 28, 2014 12:15 PM
ProjectBB6
Sep 16, 2009 02:18 PM
Renegade
Feb 21, 2008 09:07 AM
PINKS
12
Jul 8, 2006 05:27 AM
