Help with new motor
hey guys i just picked up a b18a1 w/ 240k. it's in good shape i got to test drive it before he pulled it out for me. well before i install it in my car. I wanna add acl bearings, ARP rod bolts, Cometic head gasket, and ARP head studs. this motor will be turbo and just deciding to add a little insurance. This is going to be my first time doing something like this it would be great for some advice and I got a few questions to ask you more experience guys. when i replace the bearings does the block needs to be send to the shop for any work or can i just remove the old one n put the new one in ? Replacing the head gaskets I no the head needs to be send to the shop to be deck anything else i should do while is there? And last question, should i replace the timing belt and water pump the previous owner said it was done about 25k ago.
Thanks, Bo
Thanks, Bo
Acl main and rod bearings.
Npr piston rings
Hone Block
Deck Head
Honda head gasket
Water pump
Oil pump
Arp Head Studs
Arp Mains
Valve Guides/Seals
Hondata Intake Gasket.
Timing belt.
Do it all for INSURANCE!
I did all this to my b18b1 and it runs like a champ and currently in the process of boosting her.
Npr piston rings
Hone Block
Deck Head
Honda head gasket
Water pump
Oil pump
Arp Head Studs
Arp Mains
Valve Guides/Seals
Timing belt.
GSR_ITR_BOIB
Jan 14, 2019 01:42 PM
Evil Smile
Aug 22, 2008 11:12 PM
