help needed with replacing ImputShaft Bearing
Old Apr 6, 2009 | 02:25 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default help needed with replacing ImputShaft Bearing
since the search function is the waazoo can someone help me out with the replacement of a imputshaft bearing on a 94+ LS or GSR tranny? will both be the same?..
also, while i'm replacing the bearing is there anything else i would also want to replace?
a DIY thread would be great if someone can link me
tia guys...
Old Apr 6, 2009 | 03:10 PM
iwanttokillgod's Avatar
Default Re: replacing ImputShaftBearing
if you cant answer this question how are u going to replacing ImputShaft Bearing
Old Apr 6, 2009 | 03:14 PM
gsrstick's Avatar
be nice,
Old Apr 6, 2009 | 06:07 PM
Originally Posted by gsrstick
be nice,
no
Old Apr 7, 2009 | 04:45 AM
Default Re: help needed with replacing ImputShaft Bearing
^^ go away you canadian
Old Apr 7, 2009 | 07:31 AM
dtapia's Avatar
the process is the same for both transmissions. i would replace the input shaft seal also since they do leak.when you remove the bearing the seal is located under the bearing. don't be in a hurry to do this take your time.why don't you get a helm's manual it will walk you thru step by step
drop me a email and i can send you the info.
dinotapia@sbcglobal.net
Old Apr 7, 2009 | 10:13 AM
mouab18c1's Avatar
sorry to jack threads but im in the process of needing to replace mine too...any help would be great
Old Apr 8, 2009 | 06:40 AM
thanks buddy, i wasn't sure if a helms or chilton had it in the book or not. i'll drop you an email though!
Old Apr 8, 2009 | 08:04 AM
dtapia's Avatar
info on the way.
Old Apr 9, 2009 | 05:38 AM
^^ thanks man
rustanghunter
Transmission & Drivetrain
Jun 11, 2010 07:29 PM
gutted
Aug 26, 2008 01:13 PM
bshaw
May 13, 2007 07:46 AM
jondancer
Apr 13, 2003 04:30 PM
