help me with these wires from the ecu
Old Nov 7, 2019 | 07:17 AM
komet 163's Avatar
Default help me with these wires from the ecu
Hello everyone,
does anyone know what function these wires have, and where they are connected
engine harness OBD2a
pin 6 BLU/ORN (STS)
pin 16 GRN/YEL (FLR)
pin 18 GRN ORN (MIL)
PD: they come from the connectors of the ecu but I don't know where they end
Old Nov 9, 2019 | 08:13 PM
motoxxxman's Avatar
Default Re: help me with these wires from the ecu
STS = starter signal. has voltage while cranking. Typically goes to the under dash fusebox.
FLR = fuel pump relay, aka main relay. Has voltage when the ecu decides to run the fuel pump.
MIL = Malfunction indicator lamp. aka the CEL = check engine light
Old Nov 10, 2019 | 04:07 PM
komet 163's Avatar
yes thank you so much friend ... now I just need to know specifically where they are connected to leave the harness oem
Old Nov 10, 2019 | 04:12 PM
komet 163's Avatar
here a picture of the wires coming out of the OBD2a ecu connectors
ECU connector C
ECU connector A
scottied15
Jan 2, 2013 06:08 PM
Leland
Aug 17, 2012 04:27 PM
inaety
Jun 29, 2009 11:36 AM
Teg_Your_It
Jun 17, 2006 05:08 PM
huge230
Sep 3, 2005 08:03 AM
