help me pleassssssee!
Old Jul 24, 2004 | 02:27 PM
TURBOFTW's Avatar
Default help me pleassssssee!
Ok i have a newly built LSVTEC...heres the problem i have no vtec, ive searched and searched even viewing the post about vtec troubleshooting by kamin and still i can not figure it out...heres what ive done so far...
-changed oil : 10w30 topped off
-installed oil pressure guage at 3,000 rpm i get around 55-60 psi
-no dent in oil pan
-new oil filter
-cleaned oil pickup tube again
-vtec noid clicks when hard wired
- NO check engine lights
- ive tried different ecu's that do work for a FACT
help me please, im stumped
Old Jul 26, 2004 | 05:16 AM
JimBlake's Avatar
Default Re: help me pleassssssee! (h22dude)
How did you 'hard wire' the VTEC solenoid? Does anyone know what voltage it's SUPPOSED to get?
Just an idea. I really don't know...
Most things on the car are supplied with battery voltage, & the ECU closes the ground side of the circuit. The VTEC solenoid is about the only thing that actually receives power FROM the ECU. I have no idea why Honda did it that way.
When it gets power from the ECU, I bet it's much lower than battery voltage. What's the ECU's regulated (internal) power supply? 8v? Anybody know? If you gave it battery voltage you may have fried the solenoid.
shytdoode
15
May 11, 2010 06:10 PM
yeungkaho
Mar 21, 2007 04:59 PM
05 S2K Stoner
Oct 28, 2004 06:39 PM
TURBOFTW
57
Jul 28, 2004 04:53 AM
CIVILGSR
Jun 11, 2003 07:16 AM
