help me identify these
Old Feb 7, 2004 | 09:32 AM
eghonda's Avatar
Default help me identify these
from left to right:
i believe the first is an o-ring for the water pipe, then the gasket for the oil pickup, the 3rd has me stumped, and i was told the last piece is not to be used on my b18b. can anyone confirm? thanks.
Old Feb 7, 2004 | 12:13 PM
dfoxengr's Avatar
Default Re: help me identify these (eghonda)
youre right on the first 2 dont know about the 3rd
Old Feb 7, 2004 | 12:38 PM
nickzed20's Avatar
Default Re: help me identify these (hybridvteceg)
you dont have a helms manual?
Old Feb 7, 2004 | 06:03 PM
hondatim's Avatar
Default Re: help me identify these (nickzed20)
that 3rd o-ring is either for the dipstick tube where it installs to oil pump housing, or oil pump outlet between block and oil pump housing. You will be able to tell once old pump housing is removed.
I'm pretty confident that it is the o-ring for the oil pump outlet between pump housing and block.
If you find that it is the dipstick tube o-ring, yes, you can reuse your existing o-ring on your dipstick tube but why not go ahead and install the new one?
Just letting you know.
Hope this helps...
Modified by hondatim at 9:14 PM 2/7/2004
RA21625
Feb 25, 2015 05:58 AM
LobeSex
Oct 6, 2009 01:24 AM
pjr710
Feb 24, 2009 07:05 PM
nighttrain33
Oct 3, 2006 07:30 PM
mahatma
May 4, 2006 08:38 PM
