Help! Looking for your experience and suggestions replacing valve stem seals on D16A6
Old Mar 3, 2004 | 08:18 AM
TunerToys's Avatar
Default Help! Looking for your experience and suggestions replacing valve stem seals on D16A6
Hey Guys,
So we are replacing valve stem seals on a D16A6 motor this weekend, and have decided to try it without pulling the head, using one of the air hold tools and an overhead spring compressor.
The factory manual calls for a special tool for installing the seals, which I assume is used so you do not deform the gasket, which has a metal component to it.
Has anybody replaced these seals, either using or not using a special tool? If you have not used the special tool, what did you use, and did you have good results?
Thanks a bunch for your help!
Old Mar 3, 2004 | 02:09 PM
TunerToys's Avatar
Default Re: Help! Looking for your experience and suggestions replacing valve stem seals on D16A6 (TunerToys
Bump for some help!
Old Mar 30, 2008 | 08:33 PM
Metal Head's Avatar
top
Old Mar 31, 2008 | 11:36 AM
97grnrs's Avatar
a socket works.. i always use it. tap it gently till it sits flat, but use a big enough size to not smash the rubber
Old Apr 1, 2008 | 06:27 PM
Metal Head's Avatar
cool, so OEM honda sealsa re the best or Autozone ones will work?
Kr4nG
Nov 2, 2009 01:53 PM
bb4socal
Nov 17, 2006 08:37 AM
hu
Mar 29, 2006 10:17 AM
Red D Dragon
May 5, 2005 10:16 AM
Civicr2gs5
May 5, 2004 03:18 PM
