help with ITB's!!!!!!!!!
Old Feb 28, 2007 | 09:25 AM
  #26
mmuller's Avatar
Mad Scientist
Default Re: (civicstar)
running weird is the beginning of the problems on running a stock ecu with itbs..
stock ecu uses full speed density system, itbs need alpha-n since vaccuum is low.
you can only uses speed density(map based) up to about 20/30 % throttle; after that alpha-n (tps based)
Old Feb 28, 2007 | 07:34 PM
  #27
PACMAN8's Avatar
do you guys think its ok 2 break in an all motor engine on a dyno?i did have a brand new k20 with 0 mile on it.the way i broke in that motor was the rough way i punch the **** out of it.as we all know engines have BLOCK LEARN MEMORY so its better 2 break in a brand new motor the way you would like 2 drive in the race track.i did have really good results we were 5 friends we all had the same car 2005-2006 rsx.S they baby their motor unlike me but my car was faster in any way we raced freeway runs 1/4 tracks. any wayssssssssssssss lets get back 2 the main subject what do you guys think i should do.should i put my skunk2 intake manifold on and break in my motor on stuck cames/camegears/injectors/ecu or i should just slap on my twm itb and all my internals+my s300 and take it down 2 my tuner and have him brake in my fresh fully build motor on the dyno????????????need some help.
Old Mar 1, 2007 | 04:15 AM
  #28
Cr4ck0z's Avatar
did you tried to take the rsx of your friend than try the 1/4 ?
Because i think it's the driver who make the difference and not the break-in hehe
Old Mar 3, 2007 | 04:00 PM
  #29
PACMAN8's Avatar
Default Re: (Cr4ck0z)
good one
Old Mar 5, 2007 | 06:38 PM
  #30
203_DC5's Avatar
Default Re: (PACMAN8)
Has anybody used the full-race intake manifold? how is it for an all motor set-up because i may go with that instead of ITB's. I dont know yet.
Old Mar 5, 2007 | 08:18 PM
  #31
nateg's Avatar
Default Re: (rmcdaniels)
ummm where did ur power go u lost 50 horse in 1500 rpm...time for new cams??
theidealone
Nov 3, 2010 08:23 PM
garygekko
Jun 18, 2007 07:31 AM
HCJDM1
23
Jan 24, 2007 10:19 PM
RSX8600
Sep 13, 2004 08:43 AM
Phoenix_ITR
Jul 6, 2002 12:41 AM
