help with ITB's!!!!!!!!!
Old Jan 29, 2007 | 09:49 AM
203_DC5's Avatar
Default help with ITB's!!!!!!!!!
I'm buildin an LS/VTEC and i wanna go individual throttle bodies, but my friend said that it does away with power brakes and that its really only for strictly race cars or cars that see a lot more track time then street, howver, my car is gonna be daily drivin for a lil while until i buy another car, but i dont care for creature comforts since i dont even have a sterio system in my car i just want a all out street drivin race car but i do want good brakin so if any one can help with this let me know.
Old Jan 29, 2007 | 10:00 AM
dustin_crxsi's Avatar
Default Re: help with ITB's!!!!!!!!! (LFMotorsportsowner)
It does not take away from the power brakes. You have a vaccum canaster. look around at ITB setups. You''ll see some in plain site. Thy have like 6-7 holes going into the vaccum canaster
Old Feb 17, 2007 | 12:49 PM
Cr4ck0z's Avatar
it's true what he said, in ITB you got less vacuum than a plenum ... but it's not dangerous to go on the road
Old Feb 17, 2007 | 05:00 PM
mmuller's Avatar
Mad Scientist
Default Re: help with ITB's!!!!!!!!! (dustin_crxsi)
itb's do pull a lot less vaccuum; not up to the point of your brake booster not working. brakes work fine.
they are also by every mean completely streetable, been running them everyday for about a year now.
Old Feb 18, 2007 | 05:38 AM
rmcdaniels's Avatar
Default Re: help with ITB's!!!!!!!!! (mmuller)
I daily drove mine, and it made tons of vacuum. I made a cheapie vacuum manifold for it and an adapter plate for my IACV, no problems. Throttle response was amazing.
The vacuum manifold (1' of 1" pipe, capped and tapped for 1/8" NPT hose barbs):
IACV Adapter:
Old Feb 18, 2007 | 05:42 AM
rmcdaniels's Avatar
Default Re: help with ITB's!!!!!!!!! (rmcdaniels)
More pics of that whole setup:
http://s115271005.onlinehome.us/TWM/windex.htm
http://s115271005.onlinehome.u...2.htm
http://s115271005.onlinehome.u...Pics/
Old Feb 18, 2007 | 06:12 AM
Cr4ck0z's Avatar
i did a good vacuum manifold and i measured it, i don't remember how it was but it less than a plenum
So rmc check with a gauge you will see
Old Feb 18, 2007 | 06:18 AM
Cr4ck0z's Avatar
http://s95.photobucket.com/albums/l160/Cr4ck0z/
that's mine, with a 2 1/2 piping and the vacuum is less than a normal plenum and it's normal with 4 invididual throttle body ...
Old Feb 18, 2007 | 06:21 AM
Cr4ck0z's Avatar
i don't have any loose of vacuum in my system too, and the gauge shows less than normal vacuum you must have in a normal system ... it's 18 hg the normal if i remember exactly
Old Feb 18, 2007 | 06:27 AM
rmcdaniels's Avatar
Default Re: (Cr4ck0z)
I drove it for 6 months, showed 20 on the vacuum gauge.
Old Feb 18, 2007 | 07:01 AM
mmuller's Avatar
Mad Scientist
Default Re: (rmcdaniels)
Yeah im getting about 330 mbar at idle also; as for the map sensor, you would want to use a very small vaccuum canister, just small enough to dampen pulses to make readings a little smoother.
try to make vaccuum lines as short as possible
Old Feb 19, 2007 | 04:12 AM
Cr4ck0z's Avatar
hm .... small or not the vacuum is the same everywhere ...
Old Feb 19, 2007 | 04:13 AM
Cr4ck0z's Avatar
it will not change if ur line is small or big
Old Feb 19, 2007 | 07:11 AM
mmuller's Avatar
Mad Scientist
reading is the same. its about volume; there is no need to overdue it..
put your finger over a 1/8 line and gas it; now put your hand over a throttle body and gas it, same vaccuum not same effect...( dis. dont do that or your hand might not like it..)
have tried with a bunch of different vaccuum setups, and as for now i stuck to this:
Old Feb 19, 2007 | 12:31 PM
zCivic's Avatar
Default Re: (mmuller)
I just used the G-E. Ran 4 lines to ITB, 1 to map and other to FPR. Final Large one is for the Brake booster.
Old Feb 20, 2007 | 02:43 PM
Cr4ck0z's Avatar
yeah i got that too on mine (IAC, brake booster, canister) go from a 2 1/4" pipe to a small 1/2" vacuum line .. maybe it's my butterfly that loose a little bit, my idle run very nice but maybe it loose there, i did my own butterfly so it's maybe not perfect at 100%
Old Feb 20, 2007 | 04:18 PM
mmuller's Avatar
Mad Scientist
have you synch'ed the throttle bodies?
Old Feb 20, 2007 | 06:00 PM
Cr4ck0z's Avatar
what do you mean ?
They are adjustable so yes i do if its that you mean,
Old Feb 20, 2007 | 10:24 PM
PACMAN8's Avatar
is it possible to tune twm itbs on 91oct ~11.0CR cp pistons~?
Old Feb 20, 2007 | 11:18 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (PACMAN8)
why wouldnt you? i run 91 oct with 12:1 compression. motor has been finished for about a month and ive driven it every day . going to tune thursday.
the 2000 series itb's have a booster vac line , but i tapped each runner for map signal. i pull great vacuum and the brakes work incredible.
Old Feb 21, 2007 | 02:44 AM
rmcdaniels's Avatar
I ran 93 octane with 12:1 pistons, so I don't see why not:
Old Feb 27, 2007 | 07:34 PM
PACMAN8's Avatar
will i be able 2 run my original p72 ECU/PCM in order 2 break in the motor before i tune it on dyno? i don't care if i have shity idle as long as its drivable.
Old Feb 27, 2007 | 08:46 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PACMAN8 &raquo;</TD></TR><TR><TD CLASS="quote">will i be able 2 run my original p72 ECU/PCM in order 2 break in the motor before i tune it on dyno? i don't care if i have shity idle as long as its drivable.</TD></TR></TABLE>
no way... shitty idle is an understatement
Old Feb 28, 2007 | 04:20 AM
Cr4ck0z's Avatar
you will run too rich ... not good for the motor ...
Old Feb 28, 2007 | 08:10 AM
civicstar's Avatar
yeh, stock ecu is not good to break in a motor if u have major upgrades, your better off breaking it in on the dyno or get a good wideband street tune to break it in
