Help identify LSD
Old Nov 13, 2005 | 09:12 AM
RaceCity_USA's Avatar
Banned
Default ?? Help identify LSD
Can anyone identify this LSD? I think it's for a JDM Prelude, but have no idea how to verify this.
edit: links to ebay images removed
edit: I installed an LSD from a Euro R.
Thanks,
Dave
Modified by RaceCity_USA at 1:54 PM 11/13/2005
Modified by RaceCity_USA at 10:29 PM 9/29/2008
Old Nov 13, 2005 | 11:45 AM
Banned
Default Re: ?? Help identify LSD (RaceCity_USA)
Any ideas on this?
Old Nov 13, 2005 | 06:35 PM
Boosteddc2gsr's Avatar
its not a quaife because that part number is 60.309.160
Old Nov 13, 2005 | 07:03 PM
Banned
Default Re: (Boosteddc2gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosteddc2gsr &raquo;</TD></TR><TR><TD CLASS="quote">its not a quaife because that part number is 60.309.160</TD></TR></TABLE>
Thanks Brad. Anyone else have any ideas?
Old Nov 14, 2005 | 02:35 PM
Banned
Default Re: (RaceCity_USA)
anybody have a clue?
Old Nov 15, 2005 | 10:22 AM
.RJ's Avatar
.RJ
Thats a viscous LSD from a prelude.
Old Nov 15, 2005 | 10:27 AM
95TurboCivic's Avatar
does look like a viscous for obd2 car
count the teeth on the gear and ill tell you what it goes to.
Old Nov 15, 2005 | 05:19 PM
User 5426's Avatar
Default Re: (95TurboCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TurboCivic &raquo;</TD></TR><TR><TD CLASS="quote">does look like a viscous for obd2 car
count the teeth on the gear and ill tell you what it goes to.</TD></TR></TABLE>
From the pictures, it has 60 teeth.
Lol, a pain counting those.
Old Nov 15, 2005 | 06:07 PM
Banned
Default Re: (SeaQuake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeaQuake &raquo;</TD></TR><TR><TD CLASS="quote">
Lol, a pain counting those.</TD></TR></TABLE>
I agree. I count 60 teeth also. How does a viscous LSD work and would it work well in a rear wheel drive application?
Thanks,
Dave
Old Nov 15, 2005 | 06:26 PM
trrbl1bmx's Avatar
for 60 teeth.... I don't know why I counted them.
Old Nov 15, 2005 | 06:27 PM
.RJ's Avatar
.RJ
viscous LSD's dont work all that well - your best bet is to find a OEM gear type LSD (helical, torsen, etc) but they are pretty hard to find for the prelude transmissions.
more info here - https://honda-tech.com/zerothread?id=1393262
Old Nov 16, 2005 | 07:04 AM
jonnyflo14's Avatar
You might want to head over to preludepower.com they should have some good info on LSD for the prelude transmission.
Just a thought.
Old Nov 20, 2005 | 07:49 PM
AMS MIKE's Avatar
Default Re: ?? Help identify LSD (jonnyflo14)
just an fyi.....i would stick with a helical lsd like all oem honda lsd's, quaife lsd's and cusco lsd's. If you have a M2A4 h22 tranny i would reccomend putting an aftermarket quaife lsd. If you have a M2B4 H22 tranny with no lsd in it you can put an oem jdm H22 lsd in it. The main shafts and teeth are different on M2A4 and M2B4 trannies. Therefore you have to modify too many things in the M2A4 to fit the oem honda lsd out of a M2B4 tranny.
I have had a KAAZ lsd in my h22 and i didn't like the feel of it. Its a clutch type and doesn't even compare to a helical style lsd.
cliff notes....
M2A4 = 92-96 h22 tranny with NO LSD from factory
M2B4 = 92-96 h22 tranny WITH LSD from factory
cannot put the factory LSD inside the non-factory tranny WITJOUT changing main shaft and other iternal parts.
for easy installation of LSD in a non-lsd tranny is an aftermarket helical type LSD.
hope that helps a bit.
AMS MIKE
Old Nov 21, 2005 | 10:52 AM
96b18c's Avatar
Default Re: (ilovemyef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemyef9 &raquo;</TD></TR><TR><TD CLASS="quote"> for 60 teeth.... I don't know why I counted them.</TD></TR></TABLE>
haha, even after reading your post I still counted those *****.
Old Nov 28, 2005 | 09:09 AM
The Setup's Avatar
Default Re: (96b18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96b18c &raquo;</TD></TR><TR><TD CLASS="quote">
haha, even after reading your post I still counted those *****.</TD></TR></TABLE>
... as I did as well! lol!
American.Graffiti
May 28, 2008 08:01 PM
kamAccord
Mar 8, 2007 06:05 AM
.Ryan
12
Apr 3, 2005 06:57 PM
7speed
Feb 17, 2005 08:17 PM
RI_TM
Jun 30, 2004 02:26 PM
