ECU Code 14 - BARO Sensor (Atmospheric Pressure) - WTF?
Just put a motor in and three days later (180 miles) i'm getting this ecu code. Can anyone tell me where this sensor is? Thanks in advance!
I believe it is your MAP sensor. It's either on your firewall or on top of your throttle body, with a three wire harness. HTH.
cyber13
cyber13
The barometric sensor is in the ecu. Reset the ecu and hope it doesn't come on again. If it does, check the voltage coming out of the map. At atmospheric, it should be @ 2.8-3 volts. If the map is not around that level, the ecu may think it is the internal sensor.......HTH
FSUseminoleEM1
Feb 19, 2010 08:34 AM
krz6jdm
Feb 21, 2006 01:36 AM
.brad
Feb 26, 2002 03:30 AM
