map sensor problem ,help please
Old Jan 5, 2003 | 09:39 PM
89hb's Avatar
Default map sensor problem ,help please
just swapped a 88 si intake,distributor,resistor box,and an 89teg ecu onto my 91 crx d15 swap went good crunk up on the first try but I took it to the road and the check engin light came on and the ecu threw out a code 3 what could be the problem I resett the ecu and it sill came back I tried a map out of a teg and it did the same thing but kinda worse car wold not accelerat with out it seeming like it had a fuel cut I checked the wires they seem to be fine maybe a vacume line in the wrong place where are they supossed to go anyway maybe I have them wrong could someone help me out here ? sorry this is so long
Old Jan 5, 2003 | 10:24 PM
sgT's Avatar
sgT
Default Re: map sensor problem ,help please (89hb)
there is a port on the tb for the map sensor.
but you can use any port on the plenum as well
Old Jan 6, 2003 | 02:09 AM
b19coupe's Avatar
Possible you crossed the MAP and TPS sensor connectors? Have seen that happen more than once.
Old Jan 6, 2003 | 06:11 AM
88_SC_CRX_Si's Avatar
New User
A code 3 is usally dealing with something wrong with the output, from the sensor itself. While the code 5 is dealing with wiring, connections, ect...
Dc_Ek
Feb 13, 2013 11:47 PM
mr2turbo007
Apr 23, 2012 06:22 PM
JasonST
Apr 26, 2006 07:36 AM
sakums20
Apr 29, 2004 02:40 PM
