HELP with fuel pressures for B16a JDM with ITR CAMS
New User
hello all,
im going to install a B&M fuel regulator what psi are you running at?
b16a with 01 ITR cams ITR manifold slight porting
current fuel pressure is 42 or 43 ...
she is running lean plugs are clean slight peppering ..very slight hard to see even...
thanks
thanks
Re: HELP with fuel pressures for B16a JDM with ITR CAMS (ITR607)
i never ran thne ITR IM but I did run 00'ITR cams in my jdm b16 and set fuel @ 45psi and had good results, knocked about .2 tenths.HTH
Re: HELP with fuel pressures for B16a JDM with ITR CAMS (fastwanabe)
i have a bonestock jdm b16a in my 92 cx, i'm using my cx stock fuel pump and i'm at 40 psi right now. should i adjust my fuel pressuse regulator to a higher psi? how do i know if i'm running lean or rich? by the way i'm using an ericks racing p28 ecu
i was running 38 psi, i just looked at my spark plugs today and realize i wasnt running rich. but lean. i raised the pressure to 44 psi and notice my car ran a little better than before. i'm going to raise it up higher maybe 48-50 psi and see what happens.
HT White Ops
b16a with 01 ITR cams ITR manifold slight porting current fuel pressure is 42 or 43 ...
